  • July 14, 2025, 09:20:24 PM
Author Topic: Gang Sanding (Ribs)  (Read 2626 times)
Gang Sanding (Ribs)
« on: February 04, 2016, 09:17:00 AM »
Is there a way to stack geodetic ribs and sand them all together if the wing has a tapered leading edge and tapered in thickness and there are 6 straight ribs in the center section?
Re: Gang Sanding (Ribs)
« Reply #1 on: February 04, 2016, 10:57:27 AM »
   No practical way, without the lost foam core. The lost foam system essentially does the same thing one rib at a time. If all you have are the ribs, then wait until it is assembled, and in the jig, then use a long sanding block to sand them even. Use relatively coarse paper with very light pressure and just enough time to get them even.
Offline Lauri Malila
« Reply #2 on: February 05, 2016, 07:38:58 AM »
I have allways made the ribs & glued them in place oversized, just adjusted the lenght correct.
Then sanded them true with a long, straight sanding block and plywood templates in both ends of wing panel. I like it because it gives a perfect contact between the ribs and sheeting.
But I have not used diagonal ribs, maybe it will be more difficult. Even with normal ribs you must be very carefull.
Lauri
Offline Gerald Arana
« Reply #3 on: February 05, 2016, 10:37:50 AM »
Lauri
Even with utmost care I can manage to break every (well most) rib at least once!  LL~ LL~ LL~
I built a Shark 402 and yes! I broke almost every rib! Thanks to hot stuff you couldn't tell.........
Keep sanding, Jerry
« Reply #4 on: February 05, 2016, 08:10:11 PM »
Doesn't Bobby Hunt show this on one of the lost foam video's?  Especially if you use molded leading edges.
