Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
August 01, 2025, 09:10:19 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
Belcrank controls
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Belcrank controls (Read 1692 times)
Larry Wong
Trade Count:
0
Admiral
Belcrank controls
on:
September 17, 2006, 06:52:17 PM »
I think it's been ask before, But I will ask again .. What is the diffrence of having the belcrank with reverse leads. ( front line up/ and back lead down)?
I see that the builders use both .
Logged
Larry
RC Storick
Forum owner
Administrator
Trade Count:
0
Admiral
The finish starts with the first piece of wood cut
Re: Belcrank controls
Reply #1 on:
September 17, 2006, 06:59:11 PM »
Well I will try to give you my input. I have done it both ways. T-bolt 1 has bell crank with up line on the rear. Tbolt 2 has up line in the front. There is some difference but it is slight. The lead out are also dropped 3/16 from the center line of the wing. This gives the vertical CG above the lead out outlet. (more line tension) Now with the lead out in front it seems to rotate on the line better in a hard corner.
I can't explain it very well but it works for large power plants in the nose.
Logged
Larry Wong
Trade Count:
0
Admiral
Reply #2 on:
September 17, 2006, 07:05:07 PM »
Thanks Robert I'm At the point of installing the belcrank , and I've all ways had the back line up. but I think I'll try the other , I guess it can't hurt.
Logged
Larry
Dick Fowler
Trade Count:
0
Captain
Reply #3 on:
September 17, 2006, 09:45:05 PM »
The current thought revolves around trying to compensate for yaw caused by gyroscopic precession of the prop during a turn.
Turning inside (up) creates yaw of the nose out and nose in yaw on outside maneuvers. The idea with the up line forward is that when you give up there will be more tension on the forward leadout which
if ahead of the CG
will cause the nose to yaw in to compensate.
Keeping the line spacing narrow (close together) and it really doesn't matter a whole lot.
Last Edit: September 18, 2006, 06:18:01 AM by Dick Fowler
Logged
Dick Fowler AMA 144077
Kent, OH
North Coast Control Liners Size 12 shoe XXL Supporter
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
Reply #4 on:
September 21, 2006, 03:41:05 PM »
Al Rabe is partly responsible for this. I think he may have been the first to do this to compensate for the yaw issues on hard, outside controls. But as Dick notes, it's less of an issue if the leadouts are space close together.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Building techniques
(Moderator:
RandySmith
Belcrank controls
