  • June 18, 2025, 03:20:14 PM
Author Topic: CG Ultracote Plus  (Read 1358 times)
Offline Leester
CG Ultracote Plus
« on: January 11, 2007, 02:44:28 PM »
I bought this about 1 1/2 yrs ago at a hobby shop because it was in the mark down bin. I decided to use it today but not having much luck with $kote I had my doubts especially when I found the back side was sticky. Much to my supprise it actually worked better, when I possitioned it on the wing it stayed and made the whole job so much easier. I even did a wing tip with no wrinkles ( the bottom half of one panel) 3 more to go. Are there any down sides to this covering or is it as good as it appears to be ??
Leester
ama 830538
Re: CG Ultracote Plus
« Reply #1 on: January 11, 2007, 05:44:16 PM »
Hi Lee,
Guess we'll both find out!  I plan on covering a *quick* build of a .60 size plane with it to have something new for ME to fly! **)
Offline Warren Wagner
  • Bradenton, FL
« Reply #2 on: January 11, 2007, 06:39:43 PM »
Leester,
I also found that the "Plus" version of Ultracote was indeed a pleasure to work with....the light tack to the back surface did make it easier to apply.
I found one "downside" to the "Plus" version, but it probably will NOT effect you.  I have a Time Machine built from a Dixon kit that utilizes his "Kept-Foam" technique, i.e. a foam core wing with cap strips, rather than full sheeting.   When the wing is covered, the sticky surface of the Ultracote Plus is less than a sixteenth of an inch away from the foam core.   During handling of your plane, if the Ultracote Plus is pressed down in contact with the foam core IT WILL STICK, and you will have fits getting it loose again.  It can be done, but it will test your patience.
There is a minor weight penalty in critical applications, due to the extra adhesive, but other than than, it is much nicer to work with than the standard Ultracote.  Enjoy.
Cheers.
Warren Wagner
« Last Edit: January 12, 2007, 06:49:33 PM by Warren Wagner »
Warren Wagner
AMA 1385
