  • July 16, 2025, 11:38:47 PM
Author Topic: Balsa Wood ???  (Read 1544 times)
Offline Gary Anderson
Balsa Wood ???
« on: February 25, 2010, 08:35:00 PM »
Hi guys,
I need a little help from y'all balsa wood people. A friend gave me some balsa wood blocks, I'm not sure if they're any good, weight wise???? One of the blocks is 30" long 4 1/4" wide and 2 1/8" thick. The big question, is this wood any good for building models, how can ya tell when the wood is light enough for our use???? Man I hate to use this stuff for firewood. My friend gave me, I believe 12 wood block close to this size?????? Help Help (some of the blocks are just a little lighter but most are close to 9 3/4 ounces per block????? A little help from my friends, Gary
Gary Anderson
Offline sleepy gomez
Re: Balsa Wood ???
« Reply #1 on: February 25, 2010, 09:54:46 PM »
Google the "Barton Model Flying Club", a really good  Australian site that is also a forum.  Click on forum, click on general, look under 'sticky' for balsa weight calculator.  It really works.  I use to use it for balsa now I use it for poplar and cedar since I no longer use balsa.
Offline BillLee
Re: Balsa Wood ???
« Reply #2 on: February 26, 2010, 06:07:55 AM »
Barton: a good site. http://www.controlline.org.uk/phpBB2/portal.php
Australian: not so.
Bill Lee
AMA 20018
Offline Robert McHam
Re: Balsa Wood ???
« Reply #3 on: February 26, 2010, 06:28:02 AM »
I guess there are a lot of people not aware of the download area here:
http://stunthanger.com/smf/index.php?board=14.0
According to this , a little less than 4 pounds per cubic foot. That makes it Contest grade as most see it.
Robert
Re: Balsa Wood ???
« Reply #4 on: February 26, 2010, 11:10:57 AM »
Well bust my bubble!  So the Barton site comes from England?
Re: Balsa Wood ???
« Reply #5 on: February 26, 2010, 11:21:30 AM »
If math doesn't make your head spin, and if you don't want to drag a computer into the workshop, just divide the weight of the wood in pounds by its volume in cubic feet.  This is a bit of a pain because you'll weigh it in ounces and measure it in inches, but for your block it works like this:
(9.75 oz / (16 oz/lb)) = 0.6 lb
(30 in / (12 in/ft)) = 2.5 ft
(4.25 in / (12 in/ft)) = 0.35 ft
(2.125 in / (12 in/ft)) = 0.18 ft
(0.6 lb) / ((2.5 ft)(0.35 ft)(0.18 ft)) = 3.8 lb/cu ft
Or you can find the density in oz/cu in and convert:
(9.75 oz) / ((30 in)(4.25 in)(2.125 in)) = 0.036 oz/cu in
(0.036 oz/cu in)(108 (lb/cu ft)/(oz/cu in)) = 3.9 lb/cu ft
I get two different answers because I was rounding -- but that's close enough.
Offline Jim Thomerson
Re: Balsa Wood ???
« Reply #6 on: February 26, 2010, 11:58:48 AM »
If you have 36 x 3 sheets, you can divide the weight by the thickness to get density in lbs/ft*3.
Re: Balsa Wood ???
« Reply #7 on: February 26, 2010, 04:22:47 PM »
That's very clever.  Now if only I can remember it...
Offline Larry Fulwider
Re: Balsa Wood ???
« Reply #8 on: February 27, 2010, 04:10:40 PM »
 . . . the weight in ounces . . .
       Larry Fulwider
