  • July 31, 2025, 11:20:36 AM
Author Topic: Balsa fuse sides "curl" after ply doublers dry??  (Read 1539 times)
Offline Ron Varnas
« on: August 17, 2006, 11:32:25 PM »
I've an old problem that seems to re- appear :-[
A while back I glued a set of Ply doublers on the balsa fuze sides for a Gensis 35,
I used slow curing 24 hr epoxy, applied only a thin amount to both the doublers & the
balsa, weighted the assy's down with some alloy plates on a perfectly flat surface,
after they cured I inspected the job, nice flat assy............thats until a couple of weeks
later when I had another look at them and the balsa had "curled" along the length of
the doublers :-[.....why does this happen, moisture in the workshop?, should I have
"angled" the ply - grain to 30o?.. as in this case the grain on both the doublers and
fuze sides ran the same way.
Any tips or hints greatly appreciated
RJV Melb. Australia
Offline Busby
  • ACE
Re: Balsa fuse sides "curl" after ply doublers dry??
« Reply #1 on: August 18, 2006, 11:47:34 AM »
The balsa had a higher moisture content than the ply
and after everything cured out the balsa shrank.
Are you keeping every thing in the same enviroment thru storage and building?
I have also had the same problem gluing the doublers on with a water based glue, ie thinned down Tightbond II.
Marshall Busby
Offline Ron Varnas
« Reply #2 on: August 21, 2006, 07:22:36 AM »
Right on the mark guy's :D
I took the sides indoors last week , placed them on a flat surface, and
now they have returned nice & flat ;D
need to really take care on the storage & climate of all woods in future
RJV Melb. Australia
