Building Tips and technical articles. => Building techniques => Topic started by: john e. holliday on January 18, 2016, 06:44:58 PM
Title: B-25 & Vagabond
Post by: john e. holliday on January 18, 2016, 06:44:58 PM
Now the holidays are over and the wife is back to normal(thanks for your prayers guys), I have gotten some work done on the planes.  The pic of the Vagabond is where I'm at currently and just trial fitted a fuel tank this evening.  The shots of the B-25 trial fitting the flaps and a better shot of what I have just slid together, no glue.   The shots of the wing is today after I cut the slots for the hinges.   Right now there is about 20 degree movement each way on the flaps.   Will pin the hinges once wing is covered and glued in place.   Have a lot of work to do on the engine pods yet.   Ripped up a piece of 3/4 X 1/8 aluminum bar for pads.  more later.
Title: Re: B-25 & Vagabond
Post by: Tom Niebuhr on January 19, 2016, 12:57:11 PM
Doc,
Both planes are looking great. Keep up the good work.
Post by: wwwarbird on January 19, 2016, 09:07:29 PM
 Thanks for the update Doc, that B-25 looks like kind of a monster.
Post by: Crist Rigotti on January 19, 2016, 09:44:43 PM
Looking good Doc!
Post by: Randy Powell on January 19, 2016, 10:29:45 PM
Doc, taking one of them to VSC?
Post by: john e. holliday on January 20, 2016, 12:20:42 PM
Again it looks like VSC is out of the picture,  but you never know.
Post by: Randy Powell on January 21, 2016, 01:47:14 PM
It would be cool to see you there. But I get it.
Post by: Dane Martin on January 21, 2016, 05:52:06 PM
When is vsc guys? I would like to fly with Steve Holt again.
Outstanding work doc! I've since adopted your method of clamping control surfaces for cloth and Monokote hinges. Thanks!
Post by: john e. holliday on January 21, 2016, 08:44:35 PM
In the Events section it shows March 15-19, 2016.   Glad some one like one of my ideas or way of doing things.   Tom N. and Don H would probably reconsider letting me have plans if they could see the planes in person.   Accidently poked a hole in the wing of the Vagabond..
Post by: wwwarbird on January 21, 2016, 09:52:03 PM
 It does look like you could use a little more elbowroom in the 'ol shop Doc. y1
Post by: john e. holliday on January 23, 2016, 09:09:04 PM
Had to go to Jo-Anns for some more covering material.  Had enough I covered one side of the B-25 wing.   So I got 10 yards of the Pellon P45 JAS Interfacing.  Had used it on the Vagabond and the draw back to the material is it takes a lot of dope.   So in my brilliance I put a coat of poly-crylic on the bare wood.  After it cured/dried I sanded with 200 grit paper.  It was smother than the dozen coats of dope I used on the Vagabond.   Laid the cloth in place and started brushing poly-crylic on.   On the wing tips I used the sealing iron to get the cloth to stick.   Today after I got home I finished covering the wing.  Will brush on a couple of more coats before sanding.   Yes it is rough to the touch, but not as bad as dope.   By the way the 10 yards was only $5.40 including tax with the wife's 50% discount.   Aint going mention cost difference between the quart can of SIG Butyrate and the Poly-Crylic.
Full size S-1 Ringmasters in back ground.
Post by: MarcusCordeiro on February 01, 2016, 09:45:37 AM
 8) 8) 8)
Marcus
Post by: john e. holliday on February 02, 2016, 07:32:59 PM
Well I spent a couple of days ripping a piece if aluminum and cutting to lengths.   Want to be able to swap out engines if the Fox's don't do the trick.  Used 4-40 flat heads 1/2 inch long.  Longer 4-40 will bolt the engines to the pods.   Even with all the advice here on the forum it still is slow for me.   Making a jig for further aluminum pad usage.   Nothing like duplicating things and make them match.
Post by: Glenn (Gravitywell) Reach on February 03, 2016, 12:06:58 AM
Hi John....Love watching your builds.  Just curious as to why you chose the Fox engines rather than something more modern? H^^
Post by: Paul Smith on February 03, 2016, 08:23:50 AM
Is that the Brodak B-25 kit?
Post by: john e. holliday on February 03, 2016, 10:58:50 AM
This is the plans build of Don Hutcheson's.   Been a fun and challenging build.  I have the Fox's and the .25's seem to run smoother than the old reliable stunt 35's.   I also have OS LA's and FP's along with the Brodak .25's which seem to be the weaker of the brands.
Post by: john e. holliday on February 07, 2016, 07:34:42 AM
Well the wing is glued into the B-25 fuselage and am working on the engine pods.   If you read Crist's procedure on his build in the electric section, you will see how I did it.   Also got some more dope and sanding done on the Vagabond.   Spring will be here before I'm ready.
Post by: wwwarbird on February 14, 2016, 08:07:06 PM
 How's it going on the B-25 Doc?
 BTW, really appreciating the photos, but when I click on them to enlarge and get a better look they barely get any bigger. Must be a setting on your end or? ???
Post by: john e. holliday on February 15, 2016, 10:13:36 AM
I see what you mean, but I have them edited so they will load.   If you click on the file address below the picture you can then enlarge the view.   The engine pods are on and waiting for flaps to be done and the tail surfaces.   Family keep getting in the way and keeping me out of the shop.
Post by: wwwarbird on February 15, 2016, 05:44:39 PM
 Doh, my computer illiteracies strike again! I just tried your trick and it worked, thanks for the tip Doc!  y1
Post by: john e. holliday on February 18, 2016, 08:47:48 PM
Well the B-25 now has balls.   That is ball links for the controls.  It is also in one piece minus the little detail stuff to go on it.  It is now to the part I detest, finishing.   Any volunteers?  Weight as it sits in the pic according to the scales is just under 40 ounces.   A lot of sanding to go yet.
The last three pics are the push rod hook up.   Bell crank and control horn were done by Dave Trible.
Post by: wwwarbird on February 19, 2016, 06:39:48 PM
 Thanks for the updated pics Doc, seems to be coming along fairly quickly. y1
Post by: M Spencer on February 20, 2016, 06:41:02 PM
Im sure the F Foxes will be f Fine . Or Use MORE Nitro .  ;)
8 x 6s for speed or 9 x 4s to slow it down , 9 x 5 zingers seem good , rich , for akrobatics .
I found filling the intke with the cylinder vertical ( port closed ) , sucking it in , then belting over
4 or 6 times so theyre thoroughly damp , and theyll start straight off , if the batterys good .
6 or 7 turns on the needle . the 7s probly on the 20 % N , 6 for the 10 or 15 / with 27 % oil .
maybe 24 castor , 3 Syn. coolpower .
Found if one muffler fell of the 88 , there was a slight porpoise , if Both feel of , a distinct porpoise .  :o >:D
Weenie tiny allen screws might keep them on better .  :(
Looking Good .
Post by: wwwarbird on March 18, 2016, 11:00:34 PM
 Just checking in, how's it going on the '25 Doc?
Post by: john e. holliday on March 19, 2016, 11:03:36 AM
Finally got some clear on the bare wood areas and the wing.   Was putting another coat of talc and dope on the Vagabond when wife texted dinner time.
Post by: Richard Logston on March 19, 2016, 05:58:51 PM
Doc, What ever happened to the dinner bell! Richard
Post by: john e. holliday on March 20, 2016, 05:12:28 PM
That was left on the farm many years ago. H^^
Post by: Avaiojet on March 30, 2016, 11:49:57 AM
Doc,
I've been following your Thread, it's a good one.
What stage are you at?
Charles
Post by: john e. holliday on March 30, 2016, 12:28:04 PM
Finishing
Post by: wwwarbird on May 17, 2016, 08:39:12 PM
 How we comin' here Doc? Polk City is only two weeks away! S?P ;D
Post by: john e. holliday on May 18, 2016, 10:08:49 AM
Family has held me up and the weather.   The Vagabond is ready for teat flights.  The B-25 needs a lot of finishing to do.  Pictures later as yesterday got to hold latest granddaughter at the hospital.  Probably won't make Polk City again. H^^
Post by: wwwarbird on May 18, 2016, 09:39:16 PM
 Just checkin' Doc, congrats on the new granddaughter! ;D
Post by: wwwarbird on May 30, 2016, 07:54:40 PM
 Doc,
 I'd like to go back again and review the photos of the early stages of your B-25 build, specifically the ones where you were building the wing spars etc. I've done some searching and can't seem to find that earlier thread, can you direct me to it?
Post by: john e. holliday on May 31, 2016, 09:01:41 AM
Subject:  Just couldn't Wait ,  on second page. H^^
Post by: wwwarbird on May 31, 2016, 05:47:15 PM
 Ok, I remember that one now, thanks!
Post by: john e. holliday on May 31, 2016, 11:01:22 PM
Got one flight on the Vagabond this evening, then the old Fox decided to quit working.   This is going to be one fun plane and looks great to me in the air.  Of course I may be prejuduced.   Need minor tweek on lead out guide.
Update: got to look at the Vagabond's Fox 35 Stunt.  Some how the spray bar got rotated.   Now that has been taken care of.  Ready for more flights.  Also trashed the snap on spinner after it came off when engine started yesterday. H^^
Post by: wwwarbird on August 11, 2016, 07:25:42 PM
 What's the latest on the B-25 Doc?
Post by: john e. holliday on August 12, 2016, 12:07:13 PM
Since we went from winter to summer over night it seems, have not been in the shop.   But, I have been sanding and filling.   Then sanding and filling again.   Almost ready to put seal coat over the primer.  Amazing how big this B-25 is until you start sanding on it.   Also the block sanding did not work like it should from all the dings I'm having to fill.  It closer than it was though.   I also have all kinds of excuses for not getting it done as well as not flying   HB~>
Post by: wwwarbird on August 12, 2016, 09:01:01 PM
 Really anxious to see it done and hear how it flies Doc, I really wonder if the two .19's are gonna be enough.
 I'll be digging into Hutch's P-38 design when this next building season comes around. Just got ahold of a half built one, more on that story later... ;D
Post by: john e. holliday on August 13, 2016, 12:38:34 PM
Mine will have .25 size engines for power.
Post by: wwwarbird on August 13, 2016, 09:57:19 PM
 Oh.  ;D
Post by: Sean McEntee on August 17, 2016, 09:12:17 PM
Those look awesome Doc!!  It's great to see Don's models get built.
I was hoping Don would have done a Beach 18 twin before he put his pen down.  I hear Keith Sandberg did one and I need to link up with him about it.  Have an awesome idea for a finish
Wayne might know where I'm going with that  ;D
Post by: john e. holliday on February 20, 2017, 09:59:19 AM
Well I hope it posts as it has been awhile since I've added to it.   The Vagabond has been flown and flies great after some engine run issues.  The B-25 is now ready for test flight as soon as I make a set of lines and set the engines.
Post by: wwwarbird on February 20, 2017, 06:28:23 PM
 The '25 looks great Doc, can't wait to hear how it flies and how the power choice works out.  y1
Post by: wwwarbird on May 07, 2017, 08:26:21 PM
 Hey Doc, have you flown the B-25 yet?
Post by: john e. holliday on May 08, 2017, 09:38:44 AM
Was going to fly it when stupidity stepped in.   Sure glad Dave Trible was there as well as the quad copter pilots.  Get to see results of surgery tomorrow.   The engines have been run and are ready. H^^
Post by: wwwarbird on May 08, 2017, 07:11:41 PM
 Only a few weeks 'til Polk City!  S?P ;D
Post by: badbill on May 09, 2017, 08:58:02 AM
You stick your finger in a prop ????
Post by: john e. holliday on May 09, 2017, 10:14:30 AM
I wish it was only the finger.  Some how back of hand with gas starting at the knuckles.  Less than 2 inches with 11 stitches.   Don't know what surgeon did other than two cut ligaments.  Will get to see it this afternoon.  Will be using different starting procedure next time.   Not much room between the wing LE and the engines. H^^
