  • June 15, 2025, 01:32:36 PM
Author Topic: How do you waterproof a balsa leading edge mold?  (Read 2365 times)
Offline Matt Curtis
« on: November 20, 2022, 05:33:43 PM »
So i have made a leading edge mold for s1 ringmaster out of balsa.  Could i just put a few coats of minwax polyaccrylic on it and sand smooth to make it waterproof or could i just cover it with monokote?
Re: How do you waterproof a balsa leading edge mold?
« Reply #1 on: November 20, 2022, 06:26:55 PM »
 What is the mold made from? Of it is carved from any kind of wood, the polyacrylic would do the job. Any kind of wood sealer product, lacquer, even dope. After what ever you put on it sits and cures for a few days. Give it a good coat of wax also to help keep things from sticking, and it will also help repel water also.
Offline Matt Curtis
« Reply #2 on: November 20, 2022, 06:42:50 PM »
Mold is balsa.  Thank you for the tip i thought poly would work so i will do that.  I have carnuba wax that i can put on it when i am ready to use it.  I am excited to do this to build a light ringmaster.  Will see how it goes?
Online Alan Buck
« Reply #3 on: November 20, 2022, 07:24:29 PM »
Matt i would go with z/epoxy no wax do to adhesion problems
ALAN E BUCK
« Reply #4 on: November 20, 2022, 08:07:52 PM »
I wrapped my molds with saran wrap.  Really I didn't water proof them. D>K
« Reply #5 on: November 21, 2022, 07:46:24 PM »
    Almost anything would be OK. I have rather intense dislike for polycrylic and water-based woodworking finishes. But it would be fine if that is what you have.
Online Howard Rush
« Reply #6 on: November 23, 2022, 04:28:23 PM »
I hesitate to buck Alan and Brett on mold buck waterproofing, but I use Saran Wrap.   I’m not that concerned about the grain imprinting on the balsa.
