  • June 20, 2025, 10:36:11 AM
Author Topic: Brodak P-40 kit  (Read 1751 times)
Offline Jack Mulinix
  • AMA 917877
Brodak P-40 kit
« on: June 26, 2010, 06:45:26 PM »
Just went through my new kit and have a few questions. #1. When building wing with dihedral for "fun scale" as stated in instructions, how do you get flap linkage to work? #2. What, no clear canopy in kit? #3. No preformed and soldered control horns? #4. Is the cutting the fuse as shown on plans for lightening the way to go? Sure I'll have more questions as this build goes. Thanks Jack
Re: Brodak P-40 kit
« Reply #1 on: June 26, 2010, 11:14:32 PM »
Jack,
Is this the profile P-40, Pat's design?
the amount of dihedral will really not cause a problem with the flap horn. The thing to be aware of is that you want the horn to make a straight line from the flap hole where the rod goes in, across the trailing edge, to the other flap hole. This means when you put your horn busing into the trailing edge, it will not be centered in the trailing edge. it will actually need to be a little bit high on the trailing edge.
for this profile, you could just take some sheet butyrate plastic and after making a frame, ( actually doesnt the kit have a frame, kinda thick but still,,,,) then basically laminate the flat sheet to each side of the "frame"
I am kind of surprosed there are no horns included,, I am sure we could come up with some,, though I would have thought they would be included, perhaps it was an oversite on the kit, maybe a call to Brodaks to clarify is in order.
If you are talking about making the fuse basically empty, with some "ribs:" then sheeting it, YES its the way to go, lots lighter,, LOTS
Jack, if ya wanna talk through this, give me a call, you can private message me through here, or I am in the Pampa guide as well.
  • AMA 917877
Re: Brodak P-40 kit
« Reply #2 on: June 27, 2010, 10:31:04 AM »
Thanks Mark, I'll send a pm
Re: Brodak P-40 kit
« Reply #3 on: June 28, 2010, 10:11:17 AM »
Jack,
Listen to Mark. He's built a lot of these. A lot.
  • AMA 917877
Re: Brodak P-40 kit
« Reply #4 on: June 28, 2010, 01:24:34 PM »
Thanks Randy, we had a nice talk yesterday. Indeed he's the man.
Re: Brodak P-40 kit
« Reply #5 on: June 28, 2010, 01:28:01 PM »
well I certainly have had oppurtunity to build a few of them,, and I do have a soft spot for them,,
I dont want to blame the airplane for the way I fly, but they HAVE allowed me a lot of progress, lol
Re: Brodak P-40 kit
« Reply #6 on: June 28, 2010, 02:24:22 PM »
Yea, I remember a certain purple butterfly ....
Re: Brodak P-40 kit
« Reply #7 on: June 28, 2010, 02:28:01 PM »
OUCH,,
the sharpest knife cuts the deepest,, yeah,, that one didnt give me a lot of practical experience with my flying,, damn dandelions,,
Re: Brodak P-40 kit
« Reply #8 on: July 01, 2010, 05:11:07 AM »
Hi Mark,
Something you might be interested in!  A friend of mine (architect, Expert pilot, and model designer) has some drawings for a full fuselage to use with the Brodak P-40 kit.  It looks SHARP!  LMK if you are interested.  I have seriously thought abut building one if I can find a wing.
Big Bear
Re: Brodak P-40 kit
« Reply #9 on: July 01, 2010, 01:24:48 PM »
that is interesting Bill,
I have a wing sitting on my chifrobe right now, plus a set of ribs besides.
Right now I have two projects to finish , my new profile electric, and my long ignored bf 109 that is ready for paint,,,
then of course I need a backup Pylon race plane before I take on any new projects,, but it certainly is interesting,,
Re: Brodak P-40 kit
« Reply #10 on: July 01, 2010, 09:26:04 PM »
Mark....Patrick has a .40/.46 size version of his P-40K (which flies teriffic on a .46LA). If the wing and tail are not pretty close to the P-40 ARF, I'd be surprised, but it shouldn't take much to blend the two, in any case...and get a short kit burnt out.
What class of Pylon are you flying? It looks like fun. I thought about trying it myself.
Naw, just yankin' your chain... LL~ Steve
Re: Brodak P-40 kit
« Reply #11 on: July 02, 2010, 12:32:06 AM »
Steve,
I am flying 424, otherwise known as APRA, its the "slow" version of quickie 500.
mostly Vipers, stock engine class, thunder tiger Pro .40 , stock prop. According to scuttlebut and those who report to know, they do about 130  mph. closed course with a few other like minded pilots. It is a total addreneline rush. Todd got me started, now he is flying the next step up, composite airframes and Nelson engines,, a bit pricey for me right now...
