  • June 20, 2025, 02:41:36 AM
Author Topic: CA Hinge Installation  (Read 1301 times)
Offline Dick Pacini
« on: December 14, 2009, 08:55:15 AM »
I ran across this link researching adhesives.  It is a good link with a nice video and I learned some things about CA glues.  I apologize if this is already common knowledge, but...I have been away... . :-[
http://www.rcuniverse.com/magazine/article_display.cfm?article_id=1180
AMA 62221
Re: CA Hinge Installation
« Reply #1 on: December 14, 2009, 10:34:55 AM »
Dick,
great article,
on a side note, your not planning on using CA hinges in your new stunter are you? IMHO, they introduce a LOT of friction to the controls, which on an RC plane that has a servo to recenter the surface, on our creations, it really can make life unpleasant for those critical little moments when line tension gets a bit soft!
Offline Dick Pacini
« Reply #2 on: December 14, 2009, 12:17:26 PM »
Dick,
great article,
No, I wasn't planning on using CA hinges.  I was searching for info on proper building applications for CA glues, which I have never used before, at least not in model building.  I did learn from the hinge article that the parts are assembled and then CA is applied.  The author explained the how and why which was a good lesson for me, old school "apply glue to both surfaces and then assemble."  I got smarter today! y1
AMA 62221
« Reply #3 on: December 14, 2009, 12:42:46 PM »
Dick,
great article,
I think it's more spring-back than friction.
Not that this makes much of a difference when the lines go slack and the aircraft suddenly has a mind of it's own...
Offline Leester
« Reply #4 on: December 14, 2009, 07:22:53 PM »
Well Dick just make sure you get some Debonder, and Acytone works also. It's loads of fun glueing yourself to yourself and other things  LL~ LL~
Leester
ama 830538
« Reply #5 on: December 19, 2009, 02:56:26 PM »
Here's one of the best ways to install pinned hinges, using CA glue (thin) by ***John Miller***. Almost cannot fail or have a problem. It's a .txt file...Wordpad or about anything in that line should open it.
I prefer having a removeable hinge pin (one long pin for each flap, each elevator, and the rudder, if hinged), so I'd skip the Vaseline step and remove the pins first. It's very important to get the second half to align with the first half, tho! Wax or oil the long pin, and glue with the pin installed, even if it's a raw hunk of piano wire. But this is all relatively easy, and a fine use for thin CA. Thin CA is a great way to toughen up a punky piece of light balsa, like the tips, to toughen them against hanger rash.  H^^ Steve
