  • June 16, 2025, 11:04:23 AM
Author Topic: Foam Vs Frame Weight  (Read 2056 times)
« on: August 27, 2019, 06:46:10 PM »
blank
« Last Edit: September 01, 2021, 08:36:38 AM by Motorman »
Offline Mike Alimov
Re: Foam Vs Frame Weight
« Reply #1 on: August 28, 2019, 05:33:41 PM »
Not sure you will ever get a definite answer to this - it depends on who/how the two wings are built, types of glues used, balsa density, method of built up construction, covering/ finish method, etc etc. For example, my SV-11 arf wings were about 15 oz (no flaps, covered with Brodak-cote). I have a set of sheeted SV-11 wings ( builder unknown) that are about 10 oz - who knows how much they will weigh when finished? At the same time, if you order built up sv-11 wings from Tom Morris, they will be feather light.
« Reply #2 on: August 29, 2019, 09:19:13 AM »
If comparing fully sheeted wings, the answer is closer to 2 ounces, not 4.  BTW, a fully sheeted built up is just as resistant to warps as a foamie.
If comparing a fully sheeted foamie to a open bay built up D-tube, and finishing with dope, I would expect the FINISHED weight of the foamie to be the same or lighter than built up.
« Reply #3 on: August 29, 2019, 10:44:24 AM »
Are you saying that the actual weight of just the finish for dope over sheeting is less than the finish for dope over open bay?
« Reply #4 on: August 29, 2019, 02:04:22 PM »
   Agreed, and we have abundant evidence showing what happens when a particular builder build a specific design with foam and then D-tube. They end up weighing the same, since any weight difference in the structure it compensated for in the finishing. Saving any significant weight with a D-tube requires some special circumstance, like you removed structure to the point that the D-tube is substantially less stiff.
   This tends to get swapped around when you need to make the wing removable, and thus incorporate hard points. In that case, a build-up wing makes a lot more sense, because the structure lends itself to putting hard points as spars, etc, that don't really correspond to anything in a foam wing. You can do it, but there's a lot of dead weight.
« Reply #5 on: August 30, 2019, 06:24:29 AM »
Well, a fully-sheeted wing is easier to sand than open bay.  So you have a better chance to sand off some excess material without risking a disaster.
« Reply #6 on: October 18, 2019, 08:28:29 PM »
I built several 700+ wings for the Giles series I played around with.
The wing panels complete weighed a total of about 12-13 ounces.
Finish with film added 1.5 ounces.  Silkspan and Rustoleum added another 6-7 ounces.
18-19 oz. for 700 squares.  Maybe 15-16 ounces for a 600 sq. in. wing. ready to fly.
Phil C
