Building Tips and technical articles. => Building techniques => Topic started by: Phil Spillman on August 02, 2006, 01:35:54 PM
'' I was flying my ARF Smoothie and the wing and fuselage trim has started to lift off! What is the best, most lasting way to reattach the trim to the plane? Incidentally this bird really flies quite well! I bought it from Les Nering who told me he had to route out the tank compartment to get the proper run inverted as well as upright. It truly worked out well.
OK should I clean the loosened part with alcohol, then reheat? Or apply ca? or trim solvent? or some other thing?
Phil Spillman
If it was me I'd clean it and try the trim solvent. And thats only cause I got some.
Hi Leester, Thanks for the thought! I'll let you know how it goes! Phil Spillman
Use M.E.K. to clean the underlying wood of any oil and then iron it back down. Wost case senario, recover a section.
bob branch
You can also run thinned epoxy along all of the joints of the film.
That is what is done on F2D combat planes that are shopped to the states.
