Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
June 15, 2025, 11:45:11 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
landing gear blocks, wing sheeting? Easiest way?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: landing gear blocks, wing sheeting? Easiest way? (Read 1967 times)
dave siegler
2016 supporter
Trade Count:
0
Admiral
sport flier
on:
January 21, 2021, 06:57:28 AM »
So one of the things I have struggled with is the bottom wing sheeting and cutting around the landing landing gear blocks.
The blocks are glued in and are about 1/16 proud of the wing.
How do you deal with it and make it accurate? Over the plans? multiple small pieces? or trim and fit?
Logged
Dave Siegler
NE9N extra class
AMA 720731
EAA 1231299 UAS Certificate Number FA39HY9ML7 Member of the Milwaukee Circlemasters. A Gold Leader Club for over 25 years!
http://www.circlemasters.com/
gene poremba
24 supporter
Trade Count:
0
Commander
Re: landing gear blocks, wing sheeting? Easiest way?
Reply #1 on:
January 21, 2021, 08:53:41 AM »
I simply measure and transfer those numbers over to the balsa sheeting. I guess you could lay down paper in place of the sheeting, mark the paper, cut it out and lay that over your sheeting. ...gene
Logged
Ken Bird
2020 supporter
Trade Count:
0
Ensign
Reply #2 on:
January 21, 2021, 09:27:22 AM »
I use Bob Hunt's method. He's posted a great overview here:
https://stunthanger.com/smf/building-techniques/mounting-landing-gear-in-a-foam-wing/msg132117/#msg132117
Although Bob's post mainly focuses on foam wing installation, his approach to built up wings is similar.
Logged
Ken Culbertson
25 supporter
Trade Count:
0
Admiral
Reply #3 on:
January 21, 2021, 11:15:20 AM »
I set the blocks with 4 2-56 blind nuts even with the plywood half ribs and sheet over them. Then I cut out a 1/8" smaller section than the block and replace it with a 1/32 plywood covered by a 1/32 balsa cap cover plate held by 4 small bolts with tapered heads. That way my gear mount doesn't become a VG where I don't want it.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Building techniques
(Moderator:
RandySmith
