  • July 06, 2025, 07:00:58 AM
Author Topic: Another Nobler ARF Build  (Read 6728 times)
Offline Colin McRae
  • Are we having fun yet??
« on: March 18, 2025, 12:23:57 PM »
I know it's been done to death, but I am shortly going to embark on the assembly of a Top Flite Nobler ARF. Planned power is the new Enya SS 35 EX ABC-BB engine that is quite light. I'm not going to go wild on the build but plan on the following basic ARF modifications that others have done.
- Replace the lead outs and bell crank controls
- CF pushrods w/ ball joints
- Adjustable lead out guide
- Outer adjustable wing tip weight box
- Strengthen the engine mounts with gussets
- Fuel proof the engine and fuel tank areas
One question I have relates to the nut that secures the bell crank bolt. The nut is secured with what looks to be a drop of epoxy (or maybe Loctite). The question is if there is a trick that allows the existing nut to be more easily removed. Mayne heating the nut with a soldering tool? Or some other suitable method?
Thanks in advance.
« Last Edit: May 06, 2025, 05:05:06 PM by Colin McRae »
Re: Another Nobler ARF Build
« Reply #1 on: March 18, 2025, 01:14:26 PM »
  If you can get a wrench or nut driver on it, just give it a twist and I think you'll see it flake right off. It's just supposed to resist vibration, not directly applied torque. It's a cheap, Chinese substitute so don't expect a lot from it.
   The adjustable lead outs will be a challenge just from what I have seen on the two I have messed with. They got a LOT of extra wood that isn't in a kit or plans built model that you will have to deal with. The tip eight box might be the same but you could prefabricate the box, then cut into the bottom sheeting right up against the tip rib and the spar and see how that will work. I really haven't had to deal with tip weight  on either.
  i put in some custom fitted 3/8" thick balsa with the grain running across the fuselage in between the engine mount beams to tie those together and it also gives you a real floor to support a tank. Make a top block for the front of the engine mounts to tie them together there and run it up against the firewall, after you have gotten your engine fitted and mounting hardware installed. I put a short length of 3/8" balsa between the bearers at that point also, and then you can work on gussets for the bottom. Everything gets coated with thinned epoxy when finished.
  You are on the right track with everything else.
  Dan  McEntee
Offline Colin McRae
« Reply #2 on: May 19, 2025, 03:09:44 PM »
Hi Dan
I'm trying to digest the comments above related to the addition of adjustable lead outs and tip weight box on a Nobler ARF.  I do understand the complexity involved but am trying to decide if the trim benefits they offer outweigh the work involved.
Since you have put together a couple of these ARF's, do you believe the stock (fixed) lead out location is fine as is and also the stock installed tip weight as is?
I currently have a Nobler ARF that is stock, but somewhat beat up. It actually flies reasonably well stock. The CG is 3" from the LE at the fuse and the centerline of the lead outs are 1-7/8" behind the CG. Just what the plans show. I also have a set of plans for the 'original' Nobler. And if you believe the plans, there should be 3/4oz of lead at the outer wing tip on the ARF.
So, I guess my question is if I should just forget the adj lead outs and weight box, and just do the other kit mods noted above, most importantly replace the lead outs and bell crank system, as well as beefing up the engine mounts.
Your thoughts are most welcome.
  Dan  McEntee
Offline Robert Whitley
« Reply #3 on: May 20, 2025, 09:19:43 PM »
You’re right on with the soldering iron idea to soften the glue on the bellcrank nut.
It works well.
Have fun with your Nobler!
« Reply #4 on: May 21, 2025, 08:22:47 AM »
Colin - I don't have any pictures that show how I did it but I had adjustable leadouts in my Nobler ARF.  You will need to recover the wingtip if you can find matching Whatever-it-is Kote.  I will sketch out what I did if you are interested.  I assume you are also replacing the bellcrank and leadouts.  If you do, use a 4" bellcrank, it will give you better clearance on the forward leadout.  If you are building electric the stock leadouts will be too far back.
« Reply #5 on: May 21, 2025, 08:58:50 AM »
     Sorry to take so long to reply. I'm on the road visiting my son and granddaughter in Colorado Springs, and it's been a pretty busy visit!! Things are just now settling down to a mild roar so we can rest up for the drive back home.!! I hate using my phone for this stuff and just finally got my lap top out and hooked up.
     Modifying the tip for adjustable lead outs is definitely worth the trouble, and I would not omit that step.  I would imagine most of these will benefit from some adjustment. I think it depends on the weight of the power plant that you choose and how accurate you install the wing. On the two examples I have, I was not the person that started the assembly on them. They are assembled close enough to fly for fun as a beater model. As I mentioned, I retrofitted all the usual nose upgrades and improvements, but they could have been better if I had been assembling the airplane from the start.. I think adding the re-enforcements and supports is critical to having an airplane that might last a fair amount of time. When it came to the lead outs, I just decided to hold off and see how they flew.
     The first one really needed the lead outs moved forward. I cut away the covering off the tip and found all sorts of wood glued in the hold the guide tubes in place and some other stuff I couldn't explain but to put in a slider type lead out guide would require a lot of rework and cutting stuff out. . Being the lazy sort that I am, I saw that I could just move the read guide forward to within about 3/4" of the front one. I hung the airplane by the lead outs to check it and this improved things a lot and the first flights were much better. I left that airplane as it was and started work on the second one
     The second model wasn't quite as bad but i decided to move the rear guide tube forward like I did on the first one anyway. When I cut the tip covering away, the structure on the tip of this airplane was different from the first one, more bits of wood added to anchor things down, and I couldn't easily move the tube like I could on the first one. It's kind of hard to describe, but I think I need to remove the covering from the next two rib bays to get to what needs to be cut out and altered, and I just haven't felt like doing that as yet. If I get around to assembling one from the beginning, I'll probably strip the covering completely and start from scratch if I have enough covering material. I think it all can be done much better than what I have and the final result will be a much better flying model that will last longer.
Offline Colin McRae
« Reply #6 on: May 21, 2025, 09:08:51 AM »
Thank you Ken
Yes, going to re-do the crank and lead outs, use CF rods/ball joints, beef up the engine mounts and use an adjustable wing tip weight box. And it will be IC using the new Enya SS 35 EX ABC-BB engine.
But was just going to use the stock size 3" crank but can go to 4" if recommended. The 4" size might also be better to achieve a 2:1 elev/flap ratio.
If you can offer a simple wing tip sketch for the lead outs that would be great and much appreciated.
Offline Colin McRae
« Reply #7 on: May 21, 2025, 09:22:57 AM »
Thx Dan
I'm heading in the direction of removing all the wing covering to accomplish the mods.
I acquired the Nobler ARF kit for $50 and don't know how old it is. I had another old Shoestring model I acquired that had whateverkote and the outer wing lower covering ripped off mid-air on the 3rd flight. Weakened old glue due to age I assumed. So, I will do new iron-on plus it should help with making the wing mods easier to accomplish.
Plus, there is an expected 3/4 oz lead weight on the outer wing tip that will have to be removed and replaced with the new weight box. So, a lot of wing-related work.
« Reply #8 on: May 21, 2025, 05:55:47 PM »
Thank you Ken
Simple is just not in my DNA but here goes.  I grabbed a set of Green Box plans from Outerzone.  You will see a red line where I have marked the CG from the plans.  The picture of the framed tip is from my Endgame IV.  I think that should be enough to give you the idea.  Build the tip shape with strips leaving a hole in the center then glue in the slider and frame around it.  You should be able to match the "ribs" in the tip and make it look just like the other tip with a bulge in the middle where the leadouts come out.  The picture of my ARF tip is before I converted it to electric and what is interesting is that even though they are adjustable nearly an inch in either direction they ended up almost exactly where the fixed leadouts were, just closer together which counts.  When I build my slider mounts I print out a scale and glue it to the frame.  I put the "0" on the place I select for starting setting.
(A) is the area you need to cut out of the existing tip.
(B) is the approximate length of the spar cutout you will need.
(C) is a rough sketch of what it will look like before you put the ribs back.
If you are changing controls, which you said you were, I recommend you either use a 4" bellcrank or move the 3" forward a 1/2".  You need the spar clearance for the fwd. leadout if you move the loadouts back.  When you get it all mounted make sure the leadouts clear everything with the slider full forward and full aft with full up and full down at both extremes.
PLAN "B"
Use the method Gieseke used on his Nobler(s) and most of the Bears running loose in Dallas.  A 1" long gromet and a tight fit in a series of holes in the tip.  Probably easier than a slider.  Good luck - ken
Offline Colin McRae
« Reply #9 on: May 21, 2025, 06:37:19 PM »
PLAN "B"
Thank you Ken, much appreciated.
I will be using a Brodak slider-type lead out guide. The 2 holes for the lead outs are close together at 3/4" spacing which is good. Concerning the adjustment length range at the wing tip, I already have a good idea of where the CG needs to be based on the Nobler ARF I already have. It is basically the same as the CG location shown on the original Nobler plan. Then the centerline of the lead outs placed at say 3/4" behind the CG point will be a good starting point for the center of the lead out guide location. Then be able to adjust the lead outs 1" north or south of this point. The Brodak guide has a full adjustment range of 2-1/8".
« Reply #10 on: May 21, 2025, 08:00:34 PM »
Sounds like a plan - Ken
Offline Colin McRae
« Reply #11 on: June 10, 2025, 10:52:19 AM »
For those that have never seen the stock bell crank arrangement on a Top Flite Nobler ARF, well here it is.
All I can say is WOW!
« Reply #12 on: June 10, 2025, 12:05:57 PM »
Do yourself a favor and replace that bellcrank with a good one and mount it with top support as well as bottom.
« Last Edit: June 10, 2025, 06:35:25 PM by Ken Culbertson »
« Reply #13 on: June 10, 2025, 01:26:51 PM »
   That must be a later production run kit. The bell crank assembly and even wing tip construction changed through out production. First run kits just had cable through the metal bell crank I believe and this was their cheap fix for the bell crank sawing the cable in two. Did you already remove the push rod or was it already gone? While you are at it, might as well bush the elevator horn holes if you are going to use those. Those are soft as butter and wear oblong pretty quickly.
Offline Colin McRae
« Reply #14 on: June 10, 2025, 02:09:58 PM »
I got this Nobler ARF kit for $50. The previous kit owner I guess started on some mods but did not get too far along. I did not cut the bell crank access opening. It came to me that way. So, the pushrod was already gone. Plus there are a few missing kit hardware parts. There were no horns in the box, but I have purchased new ones from Brodak. Luckily Brodak still kits the Nobler and I can get most to the missing parts I need from them.
I'm currently working on various engine bay and tank bay upgrades and putting together a clunk tank that fits in the relatively narrow tank area. Once the fuselage related mods are completed, I'll move on to the wing mods.
« Last Edit: June 11, 2025, 06:38:36 PM by Colin McRae »
Offline jerry v
« Reply #15 on: June 23, 2025, 10:23:10 AM »
I replaced the stock belcrank with the 4 inch belcrank. Replaced the control horns with the longer ones. The stock clunk fuel tank will crack at the seam in the neck area, be aware of the leak.
Jerry
Variety is the spice of life.
« Reply #16 on: June 23, 2025, 12:31:20 PM »
Removable wing?
Offline Colin McRae
« Reply #17 on: June 23, 2025, 03:22:25 PM »
Removable wing?
No plans like that on my model.
Colin
Offline Colin McRae
« Reply #18 on: June 23, 2025, 03:31:28 PM »
Jerry
I've already put together a new Sullivan 4 oz flex tank for my Nobler set up for uniflow. It fits nicely in the tank bay. Plenty of fuel for the planned Enya SS 35 EX engine as 4 oz will run that engine for close to 8 minutes.
I'm going to stay with a new 3" bell crank.
The ARF kit I acquired had a few missing hardware items including the 2 control horns. I already have new ones from Brodak.
« Reply #19 on: June 23, 2025, 06:55:03 PM »
Sorry, I forgot that the ARF had the LE dowl and bolts in the TE.  Why the 3"?  A 4" is much better.
Offline Colin McRae
« Reply #20 on: June 24, 2025, 09:26:10 AM »
Since recommended I can go with a 4" crank since I have both sizes available. I'm sure there are plenty of Noblers out there with 3", but no real downside to use a 4".
Since I am upgrading to adjustable lead outs, I might have to trim the ribs more to prevent lead out contact, but not a big deal since the wing will be fully open.
« Reply #21 on: June 24, 2025, 03:53:23 PM »
Probably more with 3" than 4".  Relative to the age of the design, they are a new thing.
There is NO downside, it is the upside of using the 4" that you want.  First better leverage which means your effective flap movement is greater and the controls slower if you so choose and, (drumroll) the larger size will mean less rib cutting for the adjustable loadouts.  I fly a much larger plane and use a 5".
Offline Colin McRae
« Reply #22 on: June 24, 2025, 04:54:38 PM »
I'm definitely into less rib cutting.
Thx Ken
Offline Colin McRae
« Reply #23 on: July 03, 2025, 12:03:58 PM »
Now that I have the Nobler ARF wing open, I have a couple of questions.
1. Adjustable lead-out centerline in relation to CG:  I currently have a somewhat beat up Nobler that I fly with the CG at 2.5" from the wing LE at the fuselage. This CG location seems pretty good in the air. This is also the kit recommended CG location.
At this CG location, the centerline of the kit fixed lead outs are a full 2-1/16" behind the CG which is a lot. My first thought is to center the new adj lead outs say 3/4" behind the CG. Then I can adjust the lead out position north and south from that point about 1" either way. So, my question is if the 3/4" centerline location behind the CG is OK, or is there a better location based on others flight experience.
2. New 4" bell crank forward lead out line:  The front lead out line is under the wing sheeting and behind the spar webbing. This will make it difficult to see if the new front lead out line will interfere with the wing ribs or other wing parts. Any experience or suggestions are welcome. In light of question 1 above, the front lead out at the wing tip with be much farther forward compared to stock.  (The rear lead out is fully accessible so no issue if and minor rib trimming is needed.)
Thx in advance.
Colin
« Reply #24 on: July 03, 2025, 01:40:59 PM »
Let me pass on what I did on my arf.  After replacing the bellcrank I removed the top ribs on the inboard tip.  I don't know what you will use so I will leave that to you.  I made mine so that the leadouts were above the C/L like they are on the ARF.  Before adding the adjustable box, find a 30+" arrow shaft and cover it with sandpaper.  Thread the forward leadout through the covered shaft and slowly grind the ribs away until you can get the forward leadout to the furthest aft position the leadouts could be with it pulled as far as it will go.  Biggest mistake in converting is to not allow for the leadouts to move without hitting something.  Make sure the aft is not hitting any ribs when the adjustable is full forward.  I think your BC is mounted behind the spar enough that this will not be a problem and the 4" will give you maby 2 ribe you don't have to sand.  You will have cut the center out of about 1/2 of the inboard spay, maybe more.  When you have it all cleared out get some stiff 1/16 x 1/8 and glue them vertically just behind where the back leadout passes through the rib with it in the full aft position.  That will replace a small amount to the crush strength from cutting the spar.
Good Luck - Ken
Offline Colin McRae
« Reply #25 on: July 03, 2025, 04:44:06 PM »
Good Luck - Ken
Thanks, Ken, for the means and methods as they will surely help. And I have removed the 3 upper wing tip ribs as you have done. I will reshape the wing tip airfoil once I have the wing tip slot installed.
But I was sort of inquiring the distance behind the CG to set the 'centerline' of the lead outs as a good zero point. Based on good flight performance, where have others set their lead out position on their Nobler ARFs?
So where is a good lead out position for a good flying Nobler ARF? The stock ARF has rudder offset and the C/L of the fixed lead outs is close to 2" behind the CG. I will be removing the rudder offset, and 2" seems way too far back.
Colin
« Reply #26 on: July 03, 2025, 06:18:06 PM »
I am sorry, you were good with the 3/4 behind the CG starting point.  Maybe an inch.  My Noblers were a bit on the aft end of the range.  I think it is the design.
Offline Colin McRae
« Reply #27 on: July 03, 2025, 07:45:36 PM »
Thx much. I'll set it up for 1" for the eventual maiden. And that is the 'centerline' of the 2 lead outs, not the forward lead out.
