  • June 15, 2025, 01:38:37 PM
Author Topic: monokote hinges vs dubro  (Read 16643 times)
Online Paul Taylor
« on: February 08, 2006, 07:53:39 PM »
When using monokote to cover a wing do most use dubro hinges or monokote hinges?
It seems that monokote would be best because you would not have to tape the hinge line.
Thoughts?
Offline RC Storick
Re: MonoKote hinges vs Dubro
« Reply #1 on: February 08, 2006, 09:14:27 PM »
I use pinned hinges but I think that just Mono Kote hinges will become brittle and wear stressed. Anybody else?
Re: monokote hinges vs dubro
« Reply #2 on: February 08, 2006, 09:16:10 PM »
Thoughts?
Monocoat hinges work very well.  I have used them a few times, but I use nylon taffeta "cloth" hinges (OTS, Clasic) or large Kleet hinges (PAMPA class) on my contest planes.
Offline builditright
  • So happy to be alive!
« Reply #3 on: February 09, 2006, 01:06:24 AM »
Hi guys,
Well here goes....  here's my first posting here.
I have used Monokote hinges for a very long time now and I do recommend them  on any sport flying model however if you are looking to use them on what I will call a "full blown stunter" I would strongly suggest you constantly make sure they are clean
Depending on the amount of flights that you put on your  "full blown stunter" you might  even want to change them after a year or so.
Now thats not saying they will become defective, it's just that a  "full blown stunter" goes through a lot more than a sport flier.
I have a webpage on how to make Monokote hinges on my website
http://www.builtrightflyright.com/MiscHelpPgs/Monokotehinges.htm
Thank you and God Bless
Walter
aka/ builditright
Offline Dave Shrum
« Reply #4 on: February 10, 2006, 03:56:22 PM »
Hey I love this site--cool set up!!
OK, loved your Web site on how to do the moncote hinges !!!
THIS IS WHEN I DID NOT HAVE DILE UP !!! :'( :'( ;D ;D
Dave Shrum
Offline Dave Shrum
« Reply #5 on: February 10, 2006, 04:00:52 PM »
WELL-THAT DID NOT MAKE ANY SENSE  !!What I meant to say was---
When on a wonderful web site that explains how to make the
monocote hinges--I WISH THAT I WAS NOT ON DIAL UP !!!!
(I got to playing with the color "thingy" and got distracted
Dave Shrum
Dave Shrum
Offline Ironbomb
« Reply #6 on: February 11, 2006, 07:04:42 AM »
Paul, try the monocote hinges. install them the entire span of the flaps and elevator. I did on my Cardinal, it was easy. I made mine wide enough so that I didnt spend two days cutting and applying the hinges. I think mine were 3in long, and two inches wide. they give great control freedom and seal the hinge line.
In the picture its hard to tell on the wing that they are there, but you can barly see them on the elevator/horizontal gap. I planed on useing monocote hinges on this plane from the start, I am pleased with the way it flys, mostly.
happy building
Greg
« Last Edit: February 11, 2006, 07:06:52 AM by Ironbomb »
Beating the crap out of the ground, one airplane at a time
Greg Bossio
AMA 834382
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #7 on: February 11, 2006, 04:12:30 PM »
I really hope those controls arenot yet hooked up, or you got a problem! (Is it showing "down" or "up"?)
Nice looking ship, though.
--Ray
--Ray
AMA902472
Offline Ironbomb
« Reply #8 on: February 11, 2006, 07:12:46 PM »
Yea Ray, they're hooked up, it turns a bit slow tho.... ;D ;D ;D
man, I'm full of it today,   naa, that is was an "in progress shot I took while I still working on it.  The finished airplane pics dont show the hinges very well.
Thanks Ray, I am pleased with the way it turned out. Well, the way the finish turned out. The fues is white appliance epoxy paint, and Sig Aerocote on the wings, and rustolum yellow on the wing tips.
This is a rebuild after my last crash with it. I thouhgt it to be indestructable, but I was wrong. It still took about a dozen and a half hard hits before the fues was done in.
Here is a pic of it before the crashes.....
I kept the same foam wing and original yellow tail feathers from the first Card. It flys with a 40FP very nicly.
I hope i didnt hi-jack your thread to badly Paul, but the black and yellow Cardinal had monocote hinges also, but not enough to seal the hinge gaps. This yellow and black version is no more.....
time to get glue on my hands some more..
Greg
Greg Bossio
AMA 834382
