  • June 19, 2025, 04:13:42 PM
Author Topic: Aliphatic resin glues  (Read 1555 times)
Offline Kim Mortimore
« on: November 05, 2010, 01:30:40 AM »
Does anyone know if all aliphatic resin glues are yellow like Titebond, or is there a brand that is white or clear?  Thanks.
Kim Mortimore
Santa Clara, CA
Re: Aliphatic resin glues
« Reply #1 on: November 05, 2010, 02:02:02 AM »
"White glue" like Elmer's is aliphatic resin; I have no clue how strong it is compared to the yellow glues.
Sig used to have a white aliphatic glue, and may still.
Offline Alan Resinger
« Reply #2 on: November 05, 2010, 09:16:46 AM »
Besides modelling I used to do a lot of work with wooden boats and used Titebond quite a bit along with a lot of West System epoxy.  Both were staples in shops for projects that I worked on.  The "Original" Titebond which is pale yellow in color is an "Aliphetic Resin" glue.  Another that modellers use is the old SIG Bond glue.  The Titebond II glue is a "Polyvinyl Acetate" glue and is just a strong and seems to dry a bit faster.  It is also water soluable like the original Titebond.  The newest offering is Titebond III which is a "proprietary polimer" glue.  I've never used it but judging by Titebond past quality, I'm sure it is a good product but not sure about modellers needs.
Offline jim gilmore
« Reply #3 on: November 05, 2010, 12:40:40 PM »
elmers is a good glue but do not get it wet.
Offline Leester
« Reply #4 on: November 06, 2010, 08:47:10 AM »
Sig's Weld Bond is a liquid resin glue. It is white but drys clear. It says it's dope proof.
Leester
ama 830538
