  • June 19, 2025, 09:47:32 AM
Author Topic: New build Thread SV 11  (Read 24399 times)
Re: New build Thread SV 11
« Reply #50 on: October 20, 2012, 06:57:11 PM »
 Stick with the ST. y1
Online Crist Rigotti
« Reply #51 on: October 20, 2012, 07:09:48 PM »
Bob,
How about some details on how you built the stab/elevators?  Did you sand a taper into them?  What # wood did you use?  Same thing for the flaps.  We want some details!   #^
Offline RC Storick
« Reply #52 on: October 20, 2012, 10:23:01 PM »
Bob,
Stab and ele are sheeted foam. Flaps are tapered 3/8. Lightest wood I had.
« Reply #53 on: October 21, 2012, 09:28:38 AM »
Great Bob.  What type of glue did you use to attach the wood to the stab and elevators?
Offline RC Storick
« Reply #54 on: October 22, 2012, 09:10:22 AM »
First I sprayed the wood with cheap hairspray. Then applied Z Poxy and squeegeed it all off. Placed in wing cradles and weighted them down and let dry over night. Final weight of Stab and ELE was 2.7 -final weight of wing was 14.3. These are finished weights less finish. The fuse is 7 OZ.
24 OZ in wood 3 oz LG engine is 13.OZ and lets say all other hardware is 6 OZ and you ad them up thats 46 OZ I am sure it will be 50. So there is 10 OZ left for finish.
« Reply #55 on: October 22, 2012, 10:34:48 AM »
Thanks for the details Bob.  Glad to see you are using epoxy for the sheeting.
Offline RC Storick
« Reply #56 on: October 24, 2012, 04:46:52 PM »
Well its all in 1 piece. Wing and flaps came in at 15.9 OZ. finished with 4 coats of dope and paper on them. I will post photos later. I guess my target weight of under 60 is out of the question. Looking for around 64 now. All the wood work (total airframe is 28 OZ now. At least this one wont have a pipe and header as added weight (or a pilot).
