  • June 21, 2025, 04:48:28 AM
Author Topic: Foam Wing Problem  (Read 1755 times)
Offline steve pagano
Foam Wing Problem
« on: October 22, 2007, 02:36:38 PM »
Hi guys;
     I am building a patternmaster foam wing and lost the cores HB~> and was wondering if any one has any tips on how to join the wings without them?
     I know the cores are an important part of joining the wings but do i really need them to get a perfectly straight wing?
                                      T.I.A.
                                          -Steve
Success isn't a destination.It's a journey!!!!!
A.M.A. 820-823
Re: Foam Wing Problem
« Reply #1 on: October 22, 2007, 04:35:17 PM »
Tou are going to have to devise a jig to hold everything perfectly aligned until the epoxy dries.  That's why the cradles (I hope you didn't lose the CORES, they ARE the wing! ;D ) are so important.  Cores are cut now pretty accurately on the C/L of the blocks so using the cradles and weighting everything down makes alignment a snap. (as usual, you have to have a flat surface to work off of)
« Reply #2 on: October 22, 2007, 04:38:41 PM »
MY mistake i ment to say cradles !!!! Man i gotta start wearing a mask when i paint  n~ **)
A.M.A. 820-823
« Reply #3 on: October 22, 2007, 04:41:01 PM »
I hear ya, Buddy! LL~ LL~ I knew what you meant. ;D
Maybe you can contact Mike Rogers, he's a Patternmaster guru and should be fairly close to you.  Check with Bobby "MR. '69 NATS" *Champione* Lampione (he's in Flushing) if you can't get up with Mike, 'cause he can. y1
Offline Roger Vizioli
  • CLiner
« Reply #4 on: October 22, 2007, 06:35:37 PM »
Steve,
 D>K
Check your e-mail.
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
steven yampolsky
« Reply #5 on: October 22, 2007, 07:33:16 PM »
1) get some 3/4" particle board or plywood from Home Depot
2) rip a 3" wide and 12" wide strip long enough to span both halfs
3) position 12" strip on a flat surface amd shimmy it so that it would lie flat and parallel to the ground. Use a long carpenter's level, at least 3' long.
4) Glue(Thick CA with kicker if you like) 3" strip to the side of the 12" strip at 90 degree angle. Make sure the top of the strip is parallel to  the ground
5) Position halfs so that the trailing edge sits atop of the 3" strip. Weigh it down so it does not move
6) shimmy halfs near the center seam so that the tops align and halfs are pushed up against each other
7) epoxy 1" wide tape along the seam. Let it dry.
8) flip the cores and repead steps 5 through 7.
Done.
  • CLiner
« Reply #6 on: October 22, 2007, 08:01:58 PM »
Steve P.
Use Steve Y.'s words and my pic to help clarify what I sent.
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Balsa Butcher
  • High Desert Flier
« Reply #7 on: October 24, 2007, 09:26:53 AM »
Ditto what Ty says - and...here is my alternate method (primary method is w/cradles).  Dry fit for perfect alignment then join w/ 5 minute epoxy.  Hold the wing panels together while maintaining alignment and make small adjustments as necessary.  You will be surprised how accurate the MK I eyeball can be when challanged.  I'm not saying that this is a better method than the ones previously mentioned nor is it an original idea, but it will work. After joining, reinforce w/fiberglass etc. ~>
Pete Cunha
Sacramento CA.
AMA 57499
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #8 on: November 07, 2007, 04:43:35 AM »
When we were using Hunt wings back in the 70's we never used the cradles.. as stated above 5 min epoxy and site down the trailing edge. I seem to remember this is the way Bobby said to do it in his instructions.
