  • August 01, 2025, 09:03:34 AM
Author Topic: Adjustable rudder  (Read 1731 times)
Offline Leester
Adjustable rudder
« on: July 01, 2006, 10:24:38 PM »
I'm going to hook up an adjustable rudder. Can you tell me the proper location (I know the rudder) and type of hardware that is best.
Leester
ama 830538
Offline Greg L Bahrman
Re: Adjustable rudder
« Reply #1 on: July 01, 2006, 10:54:03 PM »
Hi Leester,
I like to put them on the outside of the circle. This is how I do it.
I use CA hinges for this application, usually two in the fin and two in the fuse. It needs to be low enough to clear the elevator travel. Also depends where the hinge line of the rudder is. But you get the general idea.  ~>
« Last Edit: July 20, 2006, 08:26:19 PM by Greg L Bahrman »
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline Leester
« Reply #2 on: July 01, 2006, 11:07:37 PM »
Thanks Greg, looks good.
Leester
ama 830538
« Reply #3 on: July 02, 2006, 07:10:11 PM »
I do very similar to Greg with one exception.  I use a Dubro "Ball Link"  (the kind with the actual "ball post" and the cap that clamps over it), a piece of threaded rod, a nylon quick link and a horn.  One horn and quick link instead of two.  I place a small piece of ply in the fuselage side to epoxy the "post" into.  Do use epoxy to mount the post if you try that method.
A *touch* of offset can come in handy in some cases.
Bill <><
