  • June 18, 2025, 06:55:28 AM
Author Topic: Early Structure  (Read 3796 times)
Early Structure
« on: June 03, 2007, 01:21:12 PM »
Well, the wing is just underway. Just laid in one side of ribs. This is much easier than it looks. Included a pic of the completed stab. It weighs about an ounce. A little heavier than I hoped. I may toss it and do it again. We'll see.
Anyway, thought some would be interested in the structure.
Offline Leester
Re: Early Structure
« Reply #1 on: June 03, 2007, 01:55:42 PM »
Randy: What size is the stab. ? And what do you consider an acceptable wieght ? It looks just fine.
Leester
ama 830538
Offline Jim Pollock
Re: Early Structure
« Reply #2 on: June 03, 2007, 05:11:12 PM »
Randy,
One thing's sure...... It's not a Novi of any number, or even a classic for that matter!
Jim Pollock   ;D
Offline Warren Wagner
  • Bradenton, FL
Re: Early Structure
« Reply #3 on: June 03, 2007, 06:07:29 PM »
Randy,
Your posts are always interesting, as expected.
Question on the wing process...did you glue in the bottom ribs with the wing upright then flip it over, or do you manage to glue in the bottom ribs just as it looks in the picture right now?
TIA
Cheers,
Warren Wagner
Warren Wagner
AMA 1385
Re: Early Structure
« Reply #4 on: June 03, 2007, 11:11:13 PM »
Looks good so far Randy, I take it you got the lawn mowed? did you get any flying in this weekend,, keep the picts coming
Re: Early Structure
« Reply #5 on: June 03, 2007, 11:20:18 PM »
Ty,
No helium. I'll stick with balsa.
Warren,
The ribs are dropped on then the wing is flipped over. It now has all the ribs in and the spar started. I'll take a picture before I get much further.
Jim,
Nope, not a Novi. It's a Slider in disguise.
Leester,
The stab is the same, more or less, as the Slider. It was projected at .75oz. I may work on it a bit more (removing some wood) or just build another. Only thing that makes it a tough call is that it's really straight.
Mark,
Yea, lawn, weed wacking, weeding and I got about half the deck cleaned (man, I hate that bleach based deck cleaner).
All, I should have the wing ready for sheeting and get the thing into one piece in another week or so.
And no, no flying for me. Just couldn't get all the chores done this weekend. Still need to figure out how to get the forzen alternator out of the darned pickup. But that's another story....
« Last Edit: June 04, 2007, 07:44:40 AM by Randy Powell »
Offline Greg L Bahrman
Re: Early Structure
« Reply #6 on: June 04, 2007, 08:19:04 PM »
Randy,
Please send me your overweight pieces and I'll put my 76 in it. I'll even pay the heavy shipping costs.
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Re: Early Structure
« Reply #7 on: June 05, 2007, 12:16:53 PM »
Greg,
 8)
We'll see what I do. Couldn't get out to the shop last night. Had to meet with a guy about a mortgage.   :-X
Offline frank carlisle
Re: Early Structure
« Reply #8 on: June 06, 2007, 09:03:16 AM »
Here you go again Randy--------this structure looks even more delicate than what you've built in the past. Keep the pictures coming.
Frank Carlisle
Re: Early Structure
« Reply #9 on: June 06, 2007, 02:19:46 PM »
Frank,
Free Flights LOOK delicate. They seldom are. This is a bit further along. I'll take a picture later. It's working out alright so far.
Re: Early Structure
« Reply #10 on: June 06, 2007, 03:43:58 PM »
Randy,
I have to agree, when you align the inherent properties of the materials strength with the stress lines it doesnt take much mass to do the job. I would probably say "intricate" is more accurate, but oh so very cool looking, you really need to do a dyed transparent finish on one.
Re: Early Structure
« Reply #11 on: June 06, 2007, 10:01:02 PM »
Mark,
I did dyed silkspan once. Ask Rod how that's holding up (he has the plane now). Might talk to Pete Peterson sometime about how he does his. They look wonderful.
OK, here are a couple more pics of the progress. Have to finish the rear spar and install the controls. Then I can drop the rest of the half ribs on and flip it over.
I should add that the top pick was earlier in the evening. The bottom was from when I called it quits for the night.
Re: Early Structure
« Reply #12 on: June 07, 2007, 06:50:03 AM »
I'm going to have to make a wing jig like yours Randy. I'v been building on glass and gluing blocks of balsa on it to pin the LE and TE to. I like yours better.
So am I correct in assuming that you build your spar in place once you've gotten the first run of ribs glued on?
Frank Carlisle
Re: Early Structure
« Reply #13 on: June 07, 2007, 10:04:59 AM »
Caution: long, rambling post about structure and tedious building processes
Frank,
Yea, the jig is nice. If I ever get around to it, I have steel replacement upright pieces partially machined. The thing I don't like with the aluminium ones is that you are constantly checking for squareness of the pieces. I have a dozen or more than what you see here. Occasionally I have to put them into a sort of jig for the jig to get them square again. That's a pain. Some just won't come back and are tossed on the cut pile and replaced with a backup. The steel ones shouldn't be as much of a problem with that and maintain dimensional stability over time better.
You do spend a bit of time leveling the jig base. I also use a laser leveler to get the bottom chocks straight. If I'm happy with the flatness of the jig base, I can use some set blocks to set up the lower chocks, but I usually use the laser doohickey.
I set up the jig and put the leading and trailing edges in. In this case, the leading and trailing edges are compound structures. I also usually glue the wing tips in at this point. This should include the leadout adjuster and possibly tip weight box. I've been using a tube for the tip weight box, but may do it differently on this one. Once those are in, you mark the leading and trailing edges for ribs. I usually put a template on the jig base for this and use a small square to mark the rib locations. Then drop the full length strip ribs on, flip the wing over and do it again. This can be challenging if the inboard and outboard wing have significant chord asymmetry, but that usually isn't the case. If you have that, there are somethings that can be done, but I don't usually use much asymmetry so it's seldom something I have to deal with. This wing does have a half inch of asymmetry. Once that's done, I glue in the top and bottom pieces of the main spar. In this case, they were 1/8" x 1/4" "C" grain 7lb stock. You can glue some carbon fiber on these pieces before they go in if you want to, but it's been my experience that you only really need that if you use really light balsa for this. This is a very good use of the 7-10lb stock you have laying around and takes away the need for CF. One nice thing about this sort of structure is, you can use relatively heavy (7-10lb) wood (other than the sheeting). Makes for a pretty strong structure without having to use up your light wood and the wing is still very light.
Once the top and bottom of the spar are glued in, I go back with the same stuff and put in the truss supports. I've done them both parallel and perpendicular (the 1/4" dimension of the piece either in parallel with the top and bottom pieces of the spar or perpendicular to them). I seem to get better resistance to twisting the way shown in the pictures and better vertical flexion the other way. It's a crap shoot. It's one of the areas I'm still experimenting with.
Once that's done and whatever extra bracing that I want to put in, like the center section for the bellcrank and center support, I usually I put the controls in. This time I decided to go ahead and build the rear spar first. I was sort of in a groove with spar building. Doesn't really matter, though. This is also when you put in the gear blocks if you are using wing mounted gear. This one will have that, but I haven't got there yet. Once the controls and rear spar are completed, I drop on the half ribs for LE sheeting support and flip the wing again to put the half ribs on the other side. When that's done, I use a 36" long sanding block to level the ribs. Be careful at this point not to alter the airfoil (easy to do). Once that's done, flip the wing and sand the other side. This has to be done in the jig to keep things honest. When it's all nice and level (rib to rib), you can start putting sheeting on. This one is going to have pretty minimal sheeting. It will have about a half inch wide TE sheeting and the LE sheeting will also be pretty minimal with a more substantial center sheeted section. Then the capstrips go on and some block sanding can be done (in the jig).
Anyway, when that's all done, I pop it out of the jig, cut the jig tabs off the leading and trailing edge and do the final sanding and shaping and it's ready to go into the new jig with the fuselage and stab for assembly.
As I've said before, this process creates a very light and straight wing, even using somewhat heavier wood. But it is just tedious as heck to build. Lots and lots of little parts hopefully working in some kind of harmony. But I like building them. I find it relaxing.  I'm weird that way. :)
Re: Early Structure
« Reply #14 on: June 08, 2007, 06:59:07 AM »
Randy, great pictures and lots of good info.  Is your jig the one that Jim Snelson copied to make the jig he sells?  I built my P-39 wing with that jig.  Had to go purchase a 4 foot metal level to get it right tho.  Still waiting on the V blocks to be ready that he showed me at VSC.  Later,  DOC Holliday
Re: Early Structure
« Reply #15 on: June 08, 2007, 08:26:44 AM »
Doc,
I doubt Jim copied mine except maybe the idea. Same idea, though.
I don't depend on a level jig base. I do what I can to square it up, but I have a measured referrence point on the bench and use a laser level to set the bottom chocks. Jus makes it easier and you get a "flat" surface to build on even if the base is a bit out of whack.
Got the controls in last night along with the bellcrank mount and such. And I had an ephipany of sorts about the structure. Added some more wood to the main spar (probably added a quarter ounce) and it did much to increase the lateral stability of the structure. Just about done with the rear spar and then I can finish dropping on the half ribs, level the ribs and do the sheeting.
It's coming along.
Offline Ted Winterman
Re: Early Structure
« Reply #16 on: June 08, 2007, 05:16:04 PM »
       Randy,
Very beautiful structure and excellent workmanship. What will be the power-source and
target weight of the airplane?
       Ted  H^^
Re: Early Structure
« Reply #17 on: June 08, 2007, 08:14:26 PM »
Hi Ted,
Love the Sequal. Neat construction.
The engine will be either an OS 40VF or possibly a trick Tom Lay OS46VF I have stashed away. Still deciding.
The target weight is around 50oz. The plane it's modeled from, my Slider, is ~53oz. I'm doing some stuff to insure that this one is a bit lighter.
Re: Early Structure
« Reply #18 on: June 08, 2007, 10:21:15 PM »
       Randy,
Your numbers are a great goal to shoot for. I'm looking foward to watching your airplane
grow. I'll keep checking in.
       Ted   y1
Re: Early Structure
« Reply #19 on: June 10, 2007, 01:04:13 PM »
I should say that this plane is slightly bigger than the Slider. Mostly the addition of wing tips. The Slider is about 626 square inches. This plane is close to 650.
