  • June 19, 2025, 01:58:08 PM
Author Topic: VooDoo fuel tank  (Read 3423 times)
Offline Bob Disharoon
VooDoo fuel tank
« on: January 30, 2007, 06:48:32 PM »
Building a VooDoo from ebay plans....used to buy and build 25 yrs. back..need proper fuel tank size and venting configuration advise....sorry, but Im old...thnx...Bob
Offline Richard Grogan
Re: VooDoo fuel tank
« Reply #1 on: January 31, 2007, 06:40:47 AM »
What engine are you plan on using?
Long Live the CL Crowd!
                  AMA 85745
Offline Bob Zambelli
« Reply #2 on: January 31, 2007, 07:47:31 AM »
Bob - in the 60s, I built around 30 Voodoos, powered by either Fox or Johnson Combat Specials.
We used both bladder and 3 1/2 ounce metal pressure tanks, the latter fed by crankcase pressure, directly out the backplate.
LOTS OF NITRO!!!
We normally mounted the metal tanks butting up to the rear face of the leading edge and then reinforced the area with fiberglass.
We used a single outlet coming out the bottom and a single inlet into the top forward inboard corner of the tank. We fueled from the inlet and then connected it to the pressure line. Very simple, very effective.
« Reply #3 on: January 31, 2007, 10:10:37 AM »
Thanx for the info..Im flying a fox35
