  • June 15, 2025, 07:42:45 PM
Author Topic: Acceptable weight?  (Read 2457 times)
Offline Dwayne Donnelly
Acceptable weight?
« on: September 09, 2021, 02:49:32 PM »
I'm building a Genesis 35 with Bob Hunt cores,  52 inch wingspan and so far 8.7 oz. without flaps, I'm thinking that's not bad.
Re: Acceptable weight?
« Reply #1 on: September 09, 2021, 05:24:42 PM »
   That is fine.
Offline Geoff Goodworth
« Reply #2 on: September 13, 2021, 07:35:49 PM »
I have two unassembled ARC Vectors which I weighed when they were delivered.
Others who know more about these things than me say that these weights are pretty good.
I hope they help.
For info, from the Brodak website —
Wing Span:      50.5 in.
Plane Length:  42.25 in.
Wing Area:      536 sq. in.
Engine:           .32 to .40
« Reply #3 on: September 14, 2021, 06:07:44 AM »
Thanks as always Bret.
Geoff, where on the Brodak site did you find that PDF? Are there more?
Thanks you
« Reply #4 on: September 14, 2021, 07:18:56 PM »
Dwayne, the weights are the individual component weights that I measured from the ARC kits that I bought.
The only info from the Brodak site was the model specs, span, length, wing area, engine.
