  • July 08, 2025, 04:42:14 AM
Author Topic: Acceptable Clearance?  (Read 4265 times)
Offline Chris Fretz
« on: March 16, 2017, 05:13:37 PM »
Would something like this be acceptable to do to the flaps for clearance of the pushrod to the elevators?
« Last Edit: March 16, 2017, 06:23:26 PM by #Liner »
Formerly known as #Liner
AMA 1104207
Advanced
Offline Chris Fretz
Re: Acceptable Clearance?
« Reply #1 on: March 16, 2017, 05:14:26 PM »
AMA 1104207
Advanced
« Reply #2 on: March 16, 2017, 06:04:56 PM »
Looks like some of mine.  The nuts will be hard to reach, but other than that it looks fine.
As long as it moves freely and does the job, it's got enough clearance.
Offline Chris Fretz
« Reply #3 on: March 16, 2017, 06:12:08 PM »
Ooops I ment the way I cut the flaps all goofy to clear the pushrod to the elevators.
AMA 1104207
Advanced
Offline Mike Haverly
« Reply #4 on: March 16, 2017, 10:19:07 PM »
Won't hurt a thing.  Like the man said, as long it clears it will work.  Worse yet is when it rubs and makes things sticky, no good.
« Reply #5 on: March 16, 2017, 11:03:19 PM »
You're worried about the rod and link hitting the flap at full throw, right? It should be fine, but if you think it needs more clearance, it won't have to be enough to ugly it up. What plane is this?
Offline Chris Fretz
« Reply #6 on: March 17, 2017, 02:55:27 AM »
Sound advice! Thanks!
Hi Rusty,  it was hitting it so I cut clearance in the flap and copied the cut to the other flap. I just thought it looked goofy. I bought a Tanager from a fellow modeler last winter. Then at Brodak's last year someone was selling a Tanager for a heck of a price and I couldn't pass it up. So I started building the second Tanager. My back up just in case ;D
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #7 on: March 17, 2017, 02:58:55 AM »
Wile I'm at it I should ask if this one is ok before I get some good weather to paint it. Will this notch cause some trimming problems since the other side has more flap area now?
AMA 1104207
Advanced
« Reply #8 on: March 17, 2017, 12:56:11 PM »
I have notched flaps like that for years.  In fact I have even cut the flaps to look even and put a peice of scrap between the flap and fuselage on both sides.
« Reply #9 on: March 17, 2017, 02:43:47 PM »
My Twister outboard flap is notched just like that. I doubt if that notch affects anything that flyers at our level can detect.
Offline Chris Fretz
« Reply #10 on: March 17, 2017, 06:34:35 PM »
Thanks for the reply Doc! I hope you're feeling better!
That's what I was hoping to hear!
AMA 1104207
Advanced
Online Carl Cisneros
« Reply #11 on: March 17, 2017, 10:56:15 PM »
Chris
Look at teh flaps closely on my Excalibur 109 that I flew at Brodaks last year.
Notice the notching I got onthem.
Carl
Carl R Cisneros, Dist IV
Control Line RB
Offline Chris Fretz
« Reply #12 on: March 18, 2017, 01:57:57 AM »
Chris
Carl
Is that a Tomahawk hiding in the back?
AMA 1104207
Advanced
« Reply #13 on: March 18, 2017, 08:20:17 PM »
No, the smaller one is  a Sig Akromaster and the other is a Buster.
I am planning and attending the whole week this time.
Carl
Control Line RB
