Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 12, 2025, 12:53:02 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
how to fix hole in wing?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: how to fix hole in wing? (Read 1899 times)
frank carlisle
2013 Supporter
Trade Count:
0
Admiral
on:
May 03, 2007, 06:31:28 PM »
How would you fix this?
Logged
Frank Carlisle
minnesotamodeler
2014 Supporters
Trade Count:
0
Admiral
Me and my Chief Engineer
Re: how to fix hole in wing?
Reply #1 on:
May 03, 2007, 07:13:31 PM »
hmmmmm...I don't suppose, at this point, a piece of scotch tape would do, huh? (Just kidding).
How'd you do that?
Logged
--Ray
AMA902472
frank carlisle
2013 Supporter
Trade Count:
0
Admiral
Reply #2 on:
May 03, 2007, 07:17:39 PM »
Scotch tape?? That's a thought Ray, but I'm going to hold out for a while. Maybe something better will come along.
I did that when I was pulling off the stencil. Cool huh?
Logged
Frank Carlisle
minnesotamodeler
2014 Supporters
Trade Count:
0
Admiral
Reply #3 on:
May 03, 2007, 07:25:48 PM »
Yeah, bummer. How'd you do the two-tone lettering? Pretty neat.
--Ray
Logged
--Ray
AMA902472
frank carlisle
2013 Supporter
Trade Count:
0
Admiral
Reply #4 on:
May 03, 2007, 07:35:28 PM »
I painted the orange first and then masked an inch top and bottom and sprayed the center red.
I'm pretty pleased with the results except for that dang hole.
I'm sure whatever it takes to fix it will be hard to do.
AND-----It still won't fit in my truck!!
Logged
Frank Carlisle
minnesotamodeler
2014 Supporters
Trade Count:
0
Admiral
Reply #5 on:
May 03, 2007, 07:45:38 PM »
Frank,
I just had a revelation--if you chop the wings off just outside the engines, it should fit in your truck fine.
All these months of worrying, and such a simple solution!!!
--Ray
Logged
--Ray
AMA902472
Leester
2014 Supporters
Trade Count:
0
Admiral
Reply #6 on:
May 03, 2007, 07:53:20 PM »
Frank: I've seen Windy build up spots he had sanded through with rejuvinator. If you can pull the covering up with a pin or knife blade tip you could add as many coats a necessary and then sand smooth and touch up. Better than tape ?
Logged
Leester
ama 830538
frank carlisle
2013 Supporter
Trade Count:
0
Admiral
Reply #7 on:
May 03, 2007, 07:59:21 PM »
Way better than tape Lee. Thaanks. As you can see Ray just wants to chop the wings off. I like your solution better. Although Ray's fix would also have the plane fitting in my truck.
Logged
Frank Carlisle
frank carlisle
2013 Supporter
Trade Count:
0
Admiral
Reply #8 on:
May 04, 2007, 06:19:45 AM »
Hey Leester------I used clear dope (thick) and pushed it into and over the hole. It fixed it just fine. By this morning the dope was shrunk and the surface was ready for a dash of white touch up. All in all not a bad fix.
Logged
Frank Carlisle
Paul Taylor
25 supporter
Trade Count:
0
Admiral
If God is your Co-pilot - swap seats!
Reply #9 on:
May 04, 2007, 07:28:26 AM »
The small hole repair looks good Frank,
But it did not solve the
real
problem.
I think Ray was on to something.
Logged
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
Reply #10 on:
May 04, 2007, 09:23:42 AM »
Frank,
For small holes like this, I will often just dribble a little CA on it and smooth with my finger. Let it go off then sand lightly, dab on a bit of fillercoat, sand and repaint. Seems your method worked fine, though.
Logged
Leester
2014 Supporters
Trade Count:
0
Admiral
Reply #11 on:
May 05, 2007, 09:31:49 PM »
Frank: I'm happy that you got it fixed, now you can sleep better or dream about your R/C babe.
Logged
Leester
ama 830538
frank carlisle
2013 Supporter
Trade Count:
0
Admiral
Reply #12 on:
May 06, 2007, 04:16:00 AM »
Quote from: Leester on May 05, 2007, 09:31:49 PM
Yeah getting it fixed was a good thing..........BTW..my r/c babe (Roxanne) has converted to c/l. We have a circle out back and she is prego. I'm now getting a solid 8 hours of sleep a night.
Logged
Frank Carlisle
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Building techniques
(Moderator:
RandySmith
Jump to:
=> Building techniques
