  • June 15, 2025, 09:54:11 PM
Author Topic: Blue Fillet Material  (Read 24441 times)
Re: Blue Fillet Material
« Reply #50 on: May 17, 2021, 05:23:13 PM »
Charles,
I didn't want the post to degenerate to a stage where everyone else would end up being guilty of what was being complained about in the first instance!
As you well know I abhor bullying and have voiced this and stood up for you in the past. I was trying to get the thread back on track. So let's do that?
It was because of your posts I used Micro Ballons in the first place. But, there is a point where if you do not add enough balloons to the epoxy it would not sand at all!  Then, if you add too much it cracks. Mixed as per instructions Super fil does not do this. As I said, for me, Super Fil is easier.
I will re read your Gee Bee 3 Thread and search for the formula to mix the balloons to epoxy. It would be great to to sand off in less than 30 minutes, agreed.
Craig
Craig,
I use two, cut down, cups. One for the Epoxy and the other for the hardener.
If you go to my builds, you will see I add a tad of yellow paint. I do this only so I don't over mix and lose time which is needed for the application. I use 5 minute Epoxy so I must be quick.
It's kinda like mixing grout, too dry is not good and to wet is not good.
Like cake frosting. God I love white on white cake.
I've never experienced cracking in all the years I've used this stuff, but I only purchase Epoxy provided by Model suppliers, never Ace, Home Depot or Lowe's.
Yes, once you get the hang of this medium and it's application, you can do a model in an hour.
I no longer use tape either.
I don't have the patients others have, one of the reason my building isn't polished as to the fit of each piece of wood.
Tasks have to be quick, at least for me.
The Gee Bee Z I built, there's a photo someplace where I used Micro-balloons mixed with Epoxy, kinda wet and kinda dry, used inside the fiberglass wheel pants as glue.
It's all I ever used. Mixed dry, but wet enough to stick, it goes on like joint compound and sands like balsa.
It's all over my Gee Bee Z. Take a look.
I never apply this over naked wood. Always a few coats of clear Dope or Deft Wood Sealer. I always scratch and clean the area.
I'm having better results applying silk over sheeted areas using the Deft. Others use it also.
CB
Offline RC Storick
« Reply #51 on: May 17, 2021, 08:55:04 PM »
Use Super-fil for what it is supposed to be used for Fillets (Not glue) It is by far the best it beats epoxy and micro balloons and epoxolite and spackle and the rest. The only thing lighter and stronger is wood fillets. Period end of discussion!
« Reply #52 on: May 19, 2021, 04:40:39 PM »
I use BIG fillets made from wood but finding the light mushy stuff anymore is impossible.  I have tried 5min Epoxy but it never seems to dry 100%  Superfill is so forgiving and it sands so smooth.
« Reply #53 on: May 23, 2021, 08:47:53 AM »
I like the SuperFil for all the reasons listed above.  My only issue is I usually mix more than I can work or need before it starts getting stiff and end up throwing quite a bit away.. oh well.  I’m having an issue with the factory paint on one of my Chevy Equinox’s coming off and am getting a little rust spot.  I’m thinking I will use SuperFill to patch it and touch up the paint...gotta be better than Bondo.
Online wwwarbird
« Reply #54 on: May 24, 2021, 07:54:33 PM »
 Howard, any more thoughts?
Offline Steve Fitton
« Reply #55 on: August 10, 2022, 10:45:03 AM »
So, Howard, what WERE you using for fillets before the blue stuff disturbed your calm?
(I know you are busy at the Worlds, but since this thread was old already, there is no....rush.)
Offline Gerald Arana
« Reply #56 on: August 10, 2022, 06:57:45 PM »
Right on Robert. I agree 100% and use it exclusively.
Jerry
