  • July 05, 2025, 10:06:59 PM
Author Topic: "Starched" Fiberglass  (Read 2743 times)
Offline Larry Fulwider
« on: November 30, 2009, 01:06:45 PM »
Fiberglass fraying, unraveling, and distorting is a pain in the rear for me. Here is a technique some will criticize, but I like. I’ll show a small example – ‘glassing a profile nose.
(Pic 1) First, mix up a dab of washable white glue, thinned 50/50 with water. I’ve tried a thinner 2/3 water and 1/3 adhesive mix, but edge raveling was a problem.
(Pic 2) Tape down the portion of the fiberglass to a sheet of plate glass, smoothing and straightening the warp and woof. Brush on the thinned glue, keeping the ‘glass flat on the glass – no wrinkles, bubbles, or distortion. I marked a couple of dots with a felt tip showing a rough outline to brush.
(No Pic) Dab the glue completely off the brushed area with wadded paper towels. Dab straight up and down so the fiberglass does not distort. Continue until the cloth feels nearly dry, and no adhesive is visible filling the gaps between threads. Let dry overnight.
(Pics 3 & 4) Trim the starched fiberglass from the larger sheet with an X-Acto or some such. It doesn’t take an overly sharp blade to cut cleanly with no raveling at all. The working piece lifts easily from the glass (if you dabbed enough). I use a single edge blade to lift a corner.
(Pic 5) This fuzzy pic shows the cut piece draped loosely over the nose. The starched  fiberglass has about the same feel as dry heavy silkspan. I’ve not tried this on compound curves as yet, but I think it will do fine.
You might be concerned that the glass is not a strong, since the “starch” can prevent full penetration the epoxy into the cloth by partially pre-filling it. However, if you try it, I believe that concern will disappear.
I’m not sure if anyone else uses this, or a similar technique on ‘glass or silk. I don’t recall seeing it on any of the forums. I’d be interested in any variations or critiques.
I wasn’t sure about the proper use of the terms “ravel” and “unravel” – Check this out, if you are not sure either http://theurbansherpa.com/permalink.php?id=1766
   Larry Fulwider
Offline Ralph Wenzel (d)
Re: "Starched" Fiberglass
« Reply #1 on: November 30, 2009, 02:34:13 PM »
A simpler, slightly quicker technique is to lay out overlapping lengths of wax paper as large as the fiberglass you wish to treat. Then spray lightly with 3M "77", and lay the fiberglass down immediately. Let everything dry, and you can roll up the fiberglass/wax paper combo and store in a tube until needed. This will not interfere with adhesion or curing of the polyester resin.
Ralph Wenzel
AMA 495785 League City, TX
Offline Neville Legg
« Reply #2 on: November 30, 2009, 04:25:27 PM »
The method I use, is to simply spray with hairspray, (the Firm hold variety!) this holds the fibres tight enough to cut to shape with sharp scissors !
Cheers       Neville
(not) Descartes
« Reply #3 on: December 20, 2009, 10:22:36 AM »
Cheers       Neville
I had a chance to try the hairspray method on a crutch. I used the "spread on glass" method, same as I use with the water soluble adhesive (see original post pics). I used enough spray to saturate most of the 'glass.
       When dry, the 'glass lifted off the glass as easily as the water base did. The "feel", handling, and cutting of the dried material seems virtually identical with both methods.
       The significant advantages of the hairspray method are: No prep time to pre-mix, no bowls or brushes to clean, and shorter drying time. The only disadvantage is, it is a little more difficult to get the residual hairspray off the plate glass.
Thanks Neville!   H^^  From now on, I'll do it your way!
       Larry Fulwider
« Reply #4 on: December 20, 2009, 04:05:16 PM »
Larry, that's what this wonderful forum is for, to share ideas and pass on info. to help make life a little easier for us all!!! I learnt the the hairspray method when I used to cover R/C glider wings in 1/2 oz glass. I also used to pour the resin down the centre of the wing, and then spread out to the T/E and L/E with an old credit card, then use a paper towel roll to mop up the excess resin.
I've been whittling balsa for about 50 years now, and there is always something new to learn.
Glad to be of some help.
Cheers     Neville
« Last Edit: December 20, 2009, 04:29:17 PM by Neville Legg »
(not) Descartes
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #5 on: December 21, 2009, 02:07:00 AM »
I acquired from my wife a bottle of "fabric stiffener" liquid, intended (I think) for permanently draping cloth for a display, etc.  It looks like thinned Elmer's now that you mention it.  I spread it out as thin as I can get it, then hang the material by its edge with a clothespin(s) to air dry.  Works well for cloth hinge material too, you can cut and handle hinges to your heart's content without (un)raveling.
Concerning the logic of English, I always wondered about "flammable" and "inflammable".
--Ray
AMA902472
« Reply #6 on: December 21, 2009, 02:05:47 PM »
. . .  I spread it out as thin as I can get it, then hang the material by its edge with a clothespin(s) to air dry. . . .
Try the plate glass method instead of hanging. You'll like it! No little wrinkles of any kind anywhere.
Right! I didn't mention hinges is the handiest application of the method, even on the pre-cut Tom Morris ones
Or "thaw" and "unthaw". English is interesting.
I like the teacher lecturing on double negatives. Saying "I don't have no money" literally says you do have money, because what you don't have is no money.
The teacher mused, "so a double negative implies a positive" -- then chuckled, "but a double positive never implies a negative!"
From the back of the room, "Yeah, Right"  ::)
       Larry Fulwider
« Reply #7 on: December 21, 2009, 05:36:30 PM »
There are about 200 years between the words "inflammable" and "flammable" ??   Flammable being the more modern, you'll see "flammable"
on the back of trucks carrying "flammable" materials, due to the fact that "IN"flammable could be termed as a negative! and not flammable at all!! I'm English and I don't understand sometimes?? (well most of the time to be honest) But I'm thick ;D, I was always daydreaming  at school, about building a new stunter, instead of studying. Younger modelers please take note! n1
Cheers     Neville
(not) Descartes
