  • August 01, 2025, 10:14:45 PM
Author Topic: "SCARF" under construction, New Pics 2/5  (Read 1712 times)
Offline Leester
« on: January 29, 2007, 03:45:35 PM »
Since this is building season and other projects are in the finishing stages, well what the hey. I'm combining a Tutor II ARF wing and a scratch built Mustang profile that Allen Brickhaus had in FM with a foam wing. I've de ARF covered the wing and put a 4" bellcrank in with the weight box to follow. Everything else will be made from the plans. Tentative power will be an Aero Mag GP 40 stunt, and will dope and silkspan everything. I will use C/F pushrods and ball links.
« Last Edit: February 05, 2007, 05:42:05 PM by Leester »
Leester
ama 830538
Steve Kientz
Re: "SCARF" under construction
« Reply #1 on: January 30, 2007, 05:57:50 AM »
Your "stang" looks good,gives me ideas for my TUTOR II
Offline Leester
« Reply #2 on: January 30, 2007, 12:19:47 PM »
Thanks Steve: The FM plans for the Stang are CF-904 also Acetone took all the glue and left over covering off the wing with ease.
Leester
ama 830538
Steve Kientz
« Reply #3 on: January 31, 2007, 05:52:24 AM »
MY Tutor II waas finished late last fall,haven't flown it yet.I doubt it will take the punishment that my Skyray has.I did 4 touch n go's in 1 flight,talk about over control.the only damage was bent gear and a busted prop.
Offline Leester
« Reply #4 on: February 05, 2007, 05:41:08 PM »
Here's some updated pics:
Leester
ama 830538
Steve Kientz
Re: "SCARF" under construction, New Pics 2/5
« Reply #5 on: February 06, 2007, 05:53:53 AM »
Leester Great job,should look beautiful when finished.I'm about to start on my Twister fuselage,still need to mount bc and shear web in the wing.If I'm not done when good weather gets here at least I can fly my Skyray 35
Stay Warm
