  • June 19, 2025, 04:14:52 AM
Author Topic: Chipmunk trim detail  (Read 3468 times)
« on: March 03, 2008, 12:26:59 AM »
There will only be one more post after this one showing the finished plane.
Here is my trim addition to the boring fuse line and the AMA number. Time for clear coats.
Re: Chipmunk trim detail
« Reply #1 on: March 04, 2008, 01:43:20 PM »
Looking good. Clean and neat is very under rated.
Are you going to clear the canopy too?
Chris...
« Reply #2 on: March 04, 2008, 06:02:20 PM »
Chris...
No, I'm not. I can't think of a good reason to do it, but I can think of several reasons not to.
« Reply #3 on: March 04, 2008, 09:25:16 PM »
Clint,
Yea, better hustle along. When do you leave for VSC? Are you using catalyzed polyurethane?
I can't wait to leave on Sunday. I fly out at about 7am. Get there around 10am. Should be a lot of fun.
« Reply #4 on: March 04, 2008, 10:12:45 PM »
Randy, it's all dope and I leave for VSC next Wed. It has 2 clear coats on it right now. There will probably be no time to sand and polish. Oh well.
« Reply #5 on: March 05, 2008, 08:01:19 AM »
And they are??  ;D
« Reply #6 on: March 05, 2008, 07:36:58 PM »
And they are??  ;D
Well, I melted one with dope once so now I'm a little gun shy. Also, I'm afraid of peeling.
So basicly, since I don't know how to do it right, I'll just avoid the whole process.
Why would you need to anyway?
« Reply #7 on: March 06, 2008, 12:57:36 PM »
LOL!!  I never did coat my plastic canopies until Bob Hunt told me to about 15 years ago.  Anyway, you can rub out the canopy to shine more! ;D
I sand them with 800 then shoot whatever clear I am using.  The canopy will be very dull before the clear goes on, but it clears right up with the clear coats.  I mainly use Sig Canopies........
« Reply #8 on: March 06, 2008, 01:57:56 PM »
>>The canopy will be very dull before the clear goes on, but it clears right up with the clear coats. <<
You have to careful with dope to go easy the first couple of coats. Don't lay it on like latex. The thinner will disort the canopy. But if you go easy, it's not a problem. I usually sand the canopy fillets right into the canopy and sand the whole thing as Bill describes, then shoot clear over the whole thing. Works really well.
« Reply #9 on: March 06, 2008, 05:11:06 PM »
I should have mentioned the light coats to start, but then I always try to put on clear in light coats until I can tell there is some build up.  Then a fairly wet coat.
« Reply #10 on: March 19, 2008, 10:33:14 PM »
Clint,
Did you get the tail wheel and wing tip weight stuff fixed?
« Reply #11 on: March 20, 2008, 12:21:54 AM »
Clint,
Randy, I won't even have my plane back for another week or so. It's with Pete Cunha in New Mexico.
« Reply #12 on: March 20, 2008, 12:23:06 AM »
I have to say these photos don't do it justice. You should have seen it in the sun at VSC. Very nice.  y1 H^^
Thank you very much, Ty!
Offline Steve Fitton
« Reply #13 on: March 20, 2008, 12:01:53 PM »
Do bad things happen if you don't sand the canopy before applying clear?
« Reply #14 on: March 20, 2008, 03:55:59 PM »
Hi Steve,
it is for better adhesion of the paint.  Never have done it with out sanding.
« Reply #15 on: March 21, 2008, 06:51:38 PM »
Clint,  didn't I read in another post that Pete was decorating his living room with the Chipmunk?  Did I ever thank you guys for letting me sit with you at the banquet?   Every year new people, guess I'm going to have my table manners.  Have fun,  DOC Holliday
« Reply #16 on: March 22, 2008, 05:22:04 PM »
Doc, it was a pleasure to have you with us. That was the first time I met Tony Drago too.
Pete transported all our stuff, so he has all the models in New Mexico until his return to CA.
