  • July 05, 2025, 11:26:54 AM
Author Topic: "Engineered wood" for motor mounts.  (Read 17960 times)
Steve Kientz
Re: "Engineered wood" for motor mounts.
« Reply #50 on: August 17, 2007, 05:48:53 AM »
 I'm considering using ply to build up mounts. The inboard final piece would have a stringer across the very end(my nephew's Super Clown Arf has this).This plane won't be an exact clone of the Skyray,just the wing and moments. Fuselage will probably look likea '30s air racer or maybe a MiG-3(just to be different).
 1/16" ply(ganged up to1/2")then1/8" doublers back past the spar. All of this will be cross drilled and dowel pinned. I think wood as dowels are better because they absorb glue,you're not counting just on surface adhesion(like using metal).If you want to continue using metal I would look at using threaded rod and some of the newer screw holding glues.This glue is used when a screw hole has gotten worn from the screw being taken out. I've used it on some other wood projects,seems to hold up well.
Offline PatRobinson
« Reply #51 on: August 17, 2007, 07:33:34 AM »
Hi Steve,
The reason I use music wire is because it is stronger than both the wood and the epoxy joint against the up and down shear forces created by a running engine.
I had these shear forces break the glue joint in my first crutch but since  I have been using the wire no failure and more importantly no more shaking or vibration problems because a solid crutch seems to reduce all that nonsense.
The wire is also locked in by the ply doubler so it isn't going anywhere and I have never had one come out. I doubt I could hammer one out without damaging the crutch.  I really rough up the wire with a file to give the glue something to grab onto and get a good bond.
Anyway, this setup has worked sucessfully for 30 years without any problems.
I had a friend who saw my crutch and decided to use wood screws and it worked for him. I tried it but the screws weighed more than the wire and didn't add any more strength so I went back to wire.
It is interesting you mentioned threaded rod I once got the idea to use threaded rod and to glue & bolt the crutch together. It was heavier and if anything weaker because I had to remove wood to countersink for the nuts. I had all but forgotten about that one. We tend to forget our mistakes.
Steve, as long as your dowels can hold up to the ongoing shear forces I don't see a problem. The mounts made out of a glue lam of 1/16" ply should also work fine.  Plywood will compress when you tighten engine bolts so you can  drill out holes where the engine bolts go and then drill engine mount holes through the dowels or drill out and glue in aluminum or brass tubing so the engine mounting bolts goes through the tube. These are other peoples good ideas that both work and I have used both over the years.
Steve, best of luck with your project, I hope it turns out the way yo want.
        Pat Robinson
Steve Kientz
« Reply #52 on: August 18, 2007, 05:36:11 AM »
 Thanks Pat
Offline MikeyPratt
« Reply #53 on: August 25, 2007, 02:20:24 PM »
Hi Guys,
I am in the process of creating an engine crutch for a classic plane using 1/2" by 3/8" maple but the problem is trying to find straight, parallel and square wood to make it out of. I have a fair sized stock on hand and I have even raided local hobby shops to check their stocks but no joy.
I have cut down oversize stock till it was straight and true but within a day
tension in the wood grain got released by my trimming it down and I ended up with a correctly sized but bowed piece.
My question, has anyone tried to create "engineered wood". My idea is to cut
1/8" thick lengthwise strips for the top and bottom and fill the middle with vertical grain maple, use a structural epoxy like t-88 and clamp that sucker tight. When it is dry sand it true and straight. All the different grain directions should cancel out any tendency for the piece to bow.
Some questions I have are will it be strong enough? or will the vertical grain
create some unexpected harmonics or vibrations in the airframe?
So guys have any of you tried anything like this before ? What were your results?
Without feedback I am reluctant to try this out on this airplane but I may try it on a "test-mule" in the future.
I don't remember having this much trouble finding straight stock before. Perhaps, it is just my local problem or it could be the maple is now dried differently or whatever reason, it is still frustrating  HB~>.
Thanks for listening guys,
                                            Pat Robinson
Hi Pat,
Straight maple mount are hard to find sometimes.  I’ve used the following method for building engine crutches for years on different models.  Take a typical 3/8” X ½” maple engine barer and use the ½” side maple barer against the engine.   Determine the required spacing of the engine mounts make up a 3/8” medium balsa cross-grain block that fits between the maple mounts.  Glue the maple mounts and the cross-grain balsa together with slow epoxy glue and clamp together until dry.  Then trim off the outside of the barer on a belt sander to get a very clean and straight outside edge.  Make a “C” shaped engine pad from 1/8” aluminum or carbon fiber sheet and bolt or glue to the maple mount.  This also allows for additional room in the tank compartment for tank height adjustments.  Also, you can contour the front of the crutch to match the curvature of the fuselage sides from the typical F-1 fuselage former down to the plywood nose ring for the spinner.  This makes a really solid mounting platform for the engine.
Later,
Mikey
Offline PatRobinson
« Reply #54 on: August 25, 2007, 04:37:29 PM »
Hi Mikey,
I think one thing has been made abundantly clear by this thread is just like there is more than one way to skin a cat there is more than one way to build a motor mount crutch. Your idea is a very clever method for a crutch.
I have a question, many guys using a 60+ size engine use 1/2" square maple
rails for their crutch, so I was wondering if you used 1/2" size maple.
You could still contour the sides as in your example you just have a little more material to handle the stresses of a bigger engine.
I remenber seeing a Windy U. tape on his version of your style crutch and He was talking about the vibration and stresses created by the Tiger 60 engine.
This leads me to ask do modern 60+ PA / RO engines vibrate and stress a motor crutch as much as a the ST 60.  I just wondered if the new engines  needed the added strength of 1/2 square maple stock to the same degree as the ST 60.
Mikey, I appreciate you sharing your interesting crutch design.
                                                              Thank You,
                                                              Pat Robinson
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #55 on: August 25, 2007, 09:33:48 PM »
Maybe we should ask "Smiling Bob"!  H^^
You know, I've heard that after taking that stuff awhile, just whilsting a couple of bars
of Smiling Bob's song will automatically cause the wife/girlfriend to head for the bedroom..
(Sorry, like the Vonage song, I'd like to inflict a slow and painful death on the composer
of Smiling Bob's song..)
Please, please, please. Do not invoke any more of these earwigs, Dick! ;->
L.
"Some mornings, it's just not worth chewing through the leather
straps." -Emo Phillips
Offline PatRobinson
« Reply #56 on: August 26, 2007, 08:05:02 AM »
Hi Larry,
I agree that they are relentlessly irritating commercial ditties.
        Pat Robinson
Offline Bill Sawyer
« Reply #57 on: August 28, 2007, 09:53:34 PM »
I don't know if anyone has tried this but I have made and sold motor mounts in the past. I buy my wood from a local vendor that stores it where moisture can get to it - not direct rain but moist air. When I cut blanks for motor mounts thay almost always form a slight curve so I just cut them just a bit larger than the finished dimension. I store them in a low humidity area for a few days and let them dry out. Then I come back and true them up to finished dimensions. It doesn't always work but most of them I am satisfied with. I do more wood working than model airplanes so I have learned how to get around problems.
Bill Sawyer
AMA 53987
Windancer Models
Offline PatRobinson
« Reply #58 on: August 29, 2007, 07:18:48 AM »
Hi Bill,
Ironically, I started down the path to starting this thread because the pre-assembled crutch in one of your "Playboy" kits was bowed on 2 sides.
I didn't blame you because I know it was probably straight when you finished it and I know that wood will do what it will do, so I didn't even bother calling you about it. My big problem was, when I found all my own stock of maple was bowed and all my local hobby shop maple stock was bowed as well.
This is what led me to wondering about some form of engineered wood so I don't have to put up with this aggravation. I am going to try to bring some of my wood upstairs in an air conditioned space and put my bowed pieces in the oven at a very low temperature to see if I can dry them out and salvage some useable wood from what I have.
I am also going to bug Lowes to order me some thin maple and do a Glue-Lam the way Randy Powell has done.
I am beginning to think that with rock maple it is more important use epoxy to seal the crutch against humidity than it is to seal it against fuel soaking.
I now have a crutch for the Playboy that is epoxy coated and has remained dead straight for weeks which is only awaiting the engine from the tuner
so I can drill the crutch, install blind nuts and start building the kit.
Bill, thanks for your added input and ideas. This whole thread has been a learning experience about wood for me and I hope for others.
                                                              Pat Robinson
  • Red Hot Lover
    • Stephanie Miller
« Reply #59 on: August 29, 2007, 02:13:02 PM »
I use a laser cut or pin routed 3/8" birch plywood for the Mo'Best ARC/ARF profile
fuselage. It is a one piece engine mount crutch. Nose doublers are 3/32"
aircraft birch plywood over 1/64" plywood fuselage skins. The outboard (motor)
side has an additional 3/32" tripler that the engine sits on.
Not counting the inboard 1/2" balsa nose tripler, the nose thickness for the engine is
3/32" + 3/32" + 1/64" + 3/8" +1/64" + 3/32" = 25/32" > 3/4".
L.
"The first rule of intelligent tinkering is to save all the parts." - Paul Ehrlich
Offline PatRobinson
« Reply #60 on: August 29, 2007, 05:56:50 PM »
Hi Larry,
Wow! That is some front end assembly. If you have followed this thread you may have seen some guys saying that a milled out one piece crutch made out of hardwood transmits too much vibration to the plane but you aren't using hardwood and your muti-layer approach should help to negate or reduce any vibration issues.  Another advantage to this method is you avoid the tendency
of a one piece hardwood crutch to split lengthwise under an engines pounding.
Two quick questions: 1. Does it give you the solid low vibration front end results it seems designed to do. 2. Is it a "lot heavier" than a conventional
profile front end. I figured I would go ahead and ask questions some guys might have for you.
Larry, this is some very clever design work on your part.  I like It!
Thanks for your excellent contribution to the thread. I think it will be useful to guys creating their own profile plane design.
        Till next time ,
        Pat Robinson
  • Red Hot Lover
    • Stephanie Miller
« Reply #61 on: August 30, 2007, 11:17:02 AM »
I originally used 4 laminates of laser cut 3/32 birch plywood for the motor crutch
assembly. Although this worked, there were issues of alignment and thickness of
the glue. Ultimately I realized that it should simply be cut out of quality marine or
aircraft birch plywood.
Mo'Bests have always featured a very rigid nose, which allows the "stunt run",
and that is also helped by the recessed fuel tank, which locates the tank more
centrally behind the engine (it also decreases the weight of the nose assembly).
Here are some more illustrations which might give you a better feel for the nose
construction. The 1/2" balsa inboard tripler is useful in absorbing those vibrations
people are concerned about. The ARC/ARF version uses a pair of Brodak aluminum
engine clamps, which allows a number of engines to be used without nose modifications.
L.
"The reason so little is done, is generally because so little is attempted." -Samuel Smiles
Offline Keith Spriggs
    • khspriggs
« Reply #62 on: September 12, 2007, 10:15:47 PM »
A friend of mine who is a professional woodworker gave me small samples that he got at a gunstock factory. As soon as I saw it I thought that might work for motor mounts. Each ply of wood is 1/16 th inch thick. Evidently the wood is dyed before it is laminated.
Offline PatRobinson
« Reply #63 on: September 15, 2007, 03:59:54 PM »
Hi Keith,
WOW! Psychedelic motor mounts! - who would of thunk it?
Keith, let us know what kind of wood and how it works out- interesting.
                                                         Pat Robinson
Offline Bob Disharoon
« Reply #64 on: October 23, 2007, 03:06:41 PM »
Teak....try it
Offline Igor Burger
« Reply #65 on: October 24, 2007, 02:20:32 AM »
Sorry, I did not see this thread earlier. I use phenolic plate to make motor mounts. The only trouble is proper orientation, it consists of layers and they must be perpendicular to screw holes or other machining, otherwise it separates.
The advantage is clear, it very well bonds to epoxy or other glues, it is strong, it does not soak oil, it will last far stronger compression under temperature (from engine screws) and it even allows to make threads directly in the material
Disadvantages are also clear, the worst is the weight, so I use relatively small pieces (in crossection) and I use lightening on back side of motor mount. If I remember well, the weight of both pieces was almost 2oz. It needs machining as it is relatively hard and I cannot imagine to cut it out manually.
I do not see any ill effects of its strength like aplilifying vibrations or so. It is closed in balsa sides, ribs.
The construction is visible on some pictures here:
http://www.rcmodely.sk/F2B/
Offline PatRobinson
« Reply #66 on: October 25, 2007, 06:45:34 PM »
Hi Igor,
Thank you for posting you pictures and information on your phenolic motor mounts. Great precision work!!  I have 2 quick questions :
1. How did you mill out the channels in each motor rail ?
2. It looks like each  plywood former fills in the channel in each rail so how do you do that? Do you cut a slot in the former and the rail slides in or or do you glue in a piece as a filler?
Igor thank you very much! , I think your post will open some eyes to an alternative material and alternative design and also provide useful information on creating this type of crutch assembly. Outstanding  (PE**) CLP**  CLP**
                                                         Thanks again,
                                                         Pat Robinson
Offline Igor Burger
« Reply #67 on: October 26, 2007, 01:37:16 AM »
Channels are milled before cutting in larger plain piece of material.
Those channels on picture are later filled by small plywood piece glued in to seal the compartment under tank floor. On another model I just filled that opening by epoxy with microbaloons.
igor
« Reply #68 on: October 26, 2007, 03:11:18 PM »
Plain Delrin(acetal) is too soft and flexible for motor mounts.  If you want to try plastic try to get some glass-filled PET sheet.  PET glues nicely, and the glass fill will make it stiff enough for good mounts.  If you can't get PET, get glass-filled nylon, or cut down a set of the RC motor mounts for material. They work great.   Tower Hobbies Part LXJ771, LXJ772,or LXJ773 .  They are only $3-4, a lot cheaper than a sheet of plastic will be.  These mounts are probably a bit too flexible for stunt use.  Adding a heavy ply nose ring to stiffen them up might work.
