Building Tips and technical articles. => Building techniques => Topic started by: Steven Kientz on March 22, 2012, 03:42:31 PM
If I'm gonig to seal the hinge line is okay to not wrap the covering around the TE? The wing I'm recovering has flaps and I think it would be a real PITA to cover there.
if you're using a glow motor you will need to - oil will get into the wood otherwise.....not something you want .
