  • July 26, 2025, 12:38:45 PM
Author Topic: $39.95 worth of X-Acto blades  (Read 2066 times)
« on: December 19, 2007, 08:22:25 AM »
This my new tool.  Bought from Production Tool (a high quality instrustrial supplier, not Harbor), for a sale price of only $39.95.
I'd put off buying a scroll saw due the price/size/quality of previous offerings.  But when I saw this deal, I pulled the trigger.  It fits nicely at one end of my bench and I can cut-as-I-go during my usual freehand builds.
Offline Ralph Wenzel (d)
Re: $39.95 worth of X-Acto blades
« Reply #1 on: December 19, 2007, 09:48:28 AM »
Once you have the tool, Paul, the real key is to select the correct blades for the job. (One size does NOT fir all.) I get almost 100% of my Scrollsaw Blades from www.mikesworkshop.com. Good prices, extremely fast shipping, and very knowledgeable advice. Just call Mike, tell him what you're cutting, and follow his recommendatations. Wait 'til you see the sdcrollsawn Grandfather Clock on his website!
Ralph
Ralph Wenzel
AMA 495785 League City, TX
« Reply #2 on: December 19, 2007, 10:44:17 AM »
It looks like he has plenty of blades, and at good prices, too.
Maybe he has some that will cut that piece of titanium that I haven't  been able to use since 1975.
« Reply #3 on: December 19, 2007, 03:45:18 PM »
https://www.ptsxpress.com/home/home.asp
Production Tool Supply has shops all over the Detroit area, and probably elsewhere, but I'm not sure where.
This is a heavy tool, so shipping would probably kill the deal if you can't buy in persona.
« Reply #4 on: December 20, 2007, 06:56:00 PM »
I'm headed there tomorrow, the one in Novi.
« Reply #5 on: December 22, 2007, 05:33:28 PM »
Once I got my scroll saw, I don't know how I ever did with out one!  Mine sure beats my old method of cutting 1/8th" 5 ply fuselage formers with a coping saw!  Plus, I can undercut my maple motor mounts in the fuel tank area, cut tensioner spars to mount bellcranks, cut plates for removeable LG etc., etc.. I don't really know all the uses I have!
One thing I like to do is cut very shallow kerfs, about 1/4" apart, in the side of the maple mounts where they will epoxy to the ply (or balsa as the case may be) which just gives a better tooth to the epoxy bite.  I use the distance from the blade to one foot of the guide as a gauge for the cuts, maybe 1/64th" deep.
« Reply #6 on: December 23, 2007, 08:46:18 PM »
Looks exactly the same as the Harbor Fright's scroll saw (xept for color), but for a bunch less $$$. Good luck with the Ti.  http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93012   LL~ Steve
Edit: Got called to chow...best not be late for chow around here...meant to post the HF pic.
« Last Edit: December 24, 2007, 07:54:34 PM by Steve Helmick »
Offline don Burke
« Reply #7 on: December 24, 2007, 09:28:20 AM »
I had a Dremel scroll saw for many years( bought in 1962), it died of old age a few years ago.  I finally replaced it with one of the Harbor Freight ones last year.  It may be my imagination but it seems to vibrate a heck of a lot more than the Dremel.  It does work for the infrequent times I need to do something with it, mostly cutting clearance holes in plywood firewalls and similar stuff.
don Burke AMA 843
Menifee, CA
