  • July 12, 2025, 07:11:01 PM
Author Topic: Electric Prop Question  (Read 65417 times)
Offline Don Coe
« on: February 15, 2016, 09:54:43 AM »
I've got an electric P-40B Flying Tiger ARF.  Engine is the recommended 2820/07.  Instructions call for an 11 x 5.5 electric prop.  I'd like to run a 3 blade prop.  Question is, what size?    H^^
Online Tim Wescott
Re: Electric Prop Question
« Reply #1 on: February 15, 2016, 10:24:05 AM »
I'd start with a 10x5 and experiment from there.  Are there any 'lectric 3-bladers?
Offline Don Coe
« Reply #2 on: February 15, 2016, 10:29:33 AM »
Thanks for the reply Tim.  Yes, they do make 3 blade props for electric but could you use a gas/glo prop?
Offline Phil Krankowski
« Reply #3 on: February 16, 2016, 09:13:14 PM »
Yes, you can use a gas/glow prop.   A gas glow prop is thicker, heavier, and often has wider blades than the electric prop in the closest style from the same manufacturer.  Electric is lower vibration and generally run at slower RPM than glow.  Using a glow prop on electric is one way to solve prop flutter problems.
The other way around is a bad idea though.  Starting and engine vibration can break the prop.
Phil
Offline Don Coe
« Reply #4 on: February 17, 2016, 10:36:14 AM »
 H^^  Thanks for the info.
« Reply #5 on: October 16, 2016, 01:43:13 PM »
The problem with gas/glo props is they are usually thicker and heavier.. which will use more batteries vs electric props.
Offline Don Coe
« Reply #6 on: October 18, 2016, 08:40:13 AM »
I went with a Master Airscrew 10/7.  Couldn't find a 10/5.  Not a large selection.  Plane seems a little faster at the same power setting and looks a lot meaner.  I happy.
