General control line discussion => AS TIME GOES BYE => Topic started by: SQ8s on October 24, 2007, 10:50:12 PM
OK GRUNTS!!!!
How do you set up your field. Where do you put the handles, the planes, the chairs?
This fall at the Jim Walker control line circle I think theres something in the air.....and it ain't Cleveland, Detroit or Camas VD~ na# SH^
At our circle the wind is the deciding factor. The most people we have had is 4 to fly. It is also easy to see who is up next the way the planes are lined up. Usually the planes are lined up at the take off point side of the circle. The lines and handle are lined up parallel to each other outside of the circle going away from the vehicles that are on the unmowed grass outside of the circle. Chairs and boxes are close to the airplanes. Need to see it to understand what I am trying to say. Have fun, DOC Holliday
NOPE I can see it. Thanks so much 8)
I really belive that it has something to do with what side of the bed you get out of. ??? ??? ??? :)! :)! :)! to much to do so little time . Geoffrey will set his y1 y1 chair where the SUN is shineing .
Very interesting LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~
