Building Tips and technical articles. => ARF'S => Topic started by: Geoff Goodworth on August 21, 2011, 12:27:03 AM
I pulled the bellcrank out of my ARC Vector without noting how the screw was retained. I have the screw, two nuts, a plain washer and a spring washer.
Can anybody tell me which order they go back in?
Also, should I put the bellcrank back where it was (down line in front) or reverse it?
If you have the ARC version, go get a new bolt long enought to go clear thru the wing top and bottom. Install spacers to center the bellcrank in the wing. Install ply pads over the bolt top and bottom. Use epoxy for the pads. You could use a steel rod and cut groves/notches top and bottom for the epoxy to hold it in place.
