Building Tips and technical articles. => ARF'S => Topic started by: Dave Rigotti on January 23, 2020, 02:12:54 PM
If this has been answered before, I can't find where. What is the flap to elevator ratio on the Vector 40 Electric ARF? Further....What holes in the supplied horns are actually used? Closest to hinge line? Center hole? Most outer holes?
For reference I'll be using a Cobra 2820/12 (kv970), 4S 3000mah Lipo, APC 11x5.5 EP.
Thanks!
Hi Dave
I built the Vector ARF prototype for Brodak and have include a couple pix. The set-up I used and recommend is:
* Bellcrank pushrod at the bellcrank from the innermost hole
* Bellcrank rod to outermost hole on flap horn, use a ball link.
* ALSO connect the flap to elevator rod with ball link to the same screw at the flap horn - see pix below. This maximizes the throw available to the elevator.
* Flap rod to elevator also at the outermost hole. This results in a 1:1 ratio which is (pretty sure) what Randy Smith recommends. At any rate it worked great on THIS Vector
Good luck with the Vector, I think you will like it.
Dennis,
This is exactly what I asked for. Thank You for the information. The "build" is coming along nicely. The supplied bellcrank had a lot of slop in the pivot bearing so I replaced it another 4" bellcrank. Drilled to pushrod hole at 11/16". Ball links all around is planned. I spent a lot of time hinging the surfaces with Kletts. All move very free.
Thanks again!
