Building Tips and technical articles. => ARF'S => Topic started by: Rudy Taube on November 15, 2007, 05:55:55 PM
Hi Score flyer's,
1. What is the weight of your Score? Are they coming out at the TF est. of 60 to 70 oz. ?
2. Is everyone using the wing and tail take apart feature? Or are you gluing the wing and tail on?
3. Are you finding that the CG comes out per plans, or do you have to add wt. somewhere to balance the CG? TIA for your help.
Regards, H^^
Before you do anything open up the bottom of the wing at the landing gear .. they didn't put any support there , i put a balsa from spar to spar them 3/8 hardwood under the Thur hole . my score has K&B 61 and needed 1/3/4 lead in tail . stab is glued seem to tilt down ON inboard when just the 4/40 bolts were used.. wing on my is just the bolts . it fits like a glove. one more thing was the push rod tube. .Both ends bowed on the first high G loop , when i cleared the black top . i took out the 2/56 and used carbon fiber tube.also replaced leadout wires. used the stock bellcrank bushed with brass tubing. I Hope you get some help from this . Geoffrey P.S. 70oz
Hi Geoffrey,
Very complete, and helpful answer. Thank you.
Regards, H^^
Hi Rudy,
The weight of my Score with ST 51, Tru Turn spinner, Big Art tube muffler is 64 oz. I am using a 6 oz. plastic tank set up for uniflow. Six oz. is more than the ST needs, so I only use about 5.5 oz.
I removed all the factory covering, replaced the control system with good stuff (except for the sorry control horns--wish I had ditched them, too). I recovered wing/flap/stab/elevator with Ultracote, covered the fuse with silkspan and Sig dope. The wing and stab are epoxied into the fuse permanently--I hope!
If I were to do another, I would probably cover the whole thing with silkspan and dope and not use ANY of the supplied control system.
The commemts from Geoffrey about the landing gear are well founded. I bent up new struts and added anchor points just under the top sheeting for the new struts to seat into. BTW, I didn't use the wheel pants--saved a couple of oz. there.
Cheers,
Jim
Thanks Jim,
Good points all.
On my 1st three CL ARFs, FS, Nobler and P-40, I sealed all the edges, and ironed down the covering. I also put in CF push rods and ball links in all of them. They have held up OK. The P-40 now has 150 ECL flights on it with no problems.
BUT ..... I plan on taking off ALL the covering on any ARFs in the future (when I can't get the plane in an ARC) After finding out how REALLY EASY it is to take off the "chinakote" from an ARF, it is a NO brainer. It's scary how easy the chinakote FALLS off the plane, a little heat helps it come off with NO problems at all. ....... I think I can almost take off the chinakote and recover the plane with MK faster than I can iron down and seal (clear nail polish) all the seems in the original chinakote. ;) So now I can have my cake and eat it too: any plane turned into an ARC form so I can have my own color scheme that will stay there for the life of the plane. #^
I admire your adventuresome journey into the past. I have not used dope in many years, decades actually! n1
I think the Strega ARF/ARC experience will be the future of CL ARF/ARCs. It was a brilliant idea for John to go right to using the excellent Morris control systems. This was the MAIN problem with the CL ARF/ARCs. I think in the near future we will see a move in this direction. In the mean time it is not really much trouble for us to fix the problem ourselves. And fortunately, thanks to Sparky's great forum, the word has been spread to almost everyone. .... Now, if we can just find a use for the bags full of "questionable" parts we are all accumulating?? HB~>
I know I'm still preaching to the choir here, but hopefully it helps some new retread reading this post:
The only other problem is the "CA hinges". These work OK (sorta) in Dark Arts sport planes and trainers because of the servo always having the ability to overcome the initial force needed to bend the hinge, then bend the control surface. .... In CL we don't always have any "extra" force available (overhead turbulence, etc., etc, ;-) so the stiff hinges use up that last CRITICAL amount of force our slack lines have, just when we need it most! Sooooo, I hope the word gets out on these hinges like it has on the poor push rods, horns, BCs,. The Robart hinges are excellent for our CL use. Maybe John will start supplying these someday too. :!
Do you have an est. on the weight of your ST .51 and Muff? I would like to compare it to the Wt. of a Saito .62 (14.7 oz) or my ECL power system. .... TIA
Again, thanks for your input. Your's and Geoffrey's info. has been very helpful.
Regards, H^^
SCORE weight 67 oz. Stalker .66 RE ,take apart mode, over a year now no problem. New bellcrank 4",
carbon fiber pushrods,ball links, Klett hinges. I modifed mine to look like a Cobra, new wingtips, new, rudder,
basecoat clearcoat on fuse. monokote on wings and stab/elevators.
carbon fiber pushrods,ball links, Klett hinges. I modified mine to look like a Cobra, new wingtips, new, rudder,
Hi Walter,
Thanks. Sounds like the 65 to 70 oz est. by TF for the Score is correct.
Does your tail come off easily by just removing the two bolts? Or did you do some mods to the removable tail? .... The wing looks like a standard "Dark Arts" reliable system.
Regards, H^^
Rudy,
Tail does not come off on mine , however I have seen some that modifed the Score to have this feature.
Rudy,
Tail does not come off on mine , however I have seen some that modified the Score to have this feature.
Thanks Walter,
This is good news. I am trying to find a compition CL plane that will fit in a box that I can take on a plane to go to contests beyond normal driving distances, but one that does not cost $4,000 n~ I found with my Dark Arts planes that even large planes become manageable if you can take off the wings, horizontal stab/El, and the LG.
Regards, H^^
My Score came out at 67 oz with ST51 and two ounces of lead on the firewall. Like everybody else I suggest a complete replacement of all stock controls and a 4" nylon or Tom Morris bellcrank. Lots and lots has been written about mods to the Score. Check the Stuka Stunt archives. It is a great flyer and very capable. There is an electric powered one flying here in the San Francisco area that performs very well. At minimum change out hinges, bellcrank, leadouts, pushrods (carbon tubes), ball joints, horn bushings (to carry much of the load rather than the hinges). I built mine with removable stab/elevator so the whole thing goes in a long narrow box. I had to shim the stab to get it co-planar with the wing. No problem with hold-down screws coming loose, but of course check them regularly. RC models have been built like this for decades, a very tried and proven system.
Hi Mike,
Thank you for the great info. All good news! :-)
Do you have any photos and/or dimensions of your shipping box? Sounds like it is just what I need.
Do you have the name or any info on the person that has the ECL Score? TIA
Regards, H^^
Hi Rudy:
I got the idea for the box from Eric, the electric Score flyer who lives in San Francisco. I don't recall his last name but it is in contest results for this area and somebody hereabouts must know his last name. He just appeared on the scene this season so I don't know him well. The model box is actually a black plastic telescoping device called Sport Tube, and is made for transporting snowboards. There are several sizes (cross section); mine is about 12 by 14 inches in rectangular cross section, and telescopes to about 70 inches. The "telescoped" length is adjustable in increments of about two inches. The thing is virtually indestructable. I took my take-apart Smoothie to England in it in August. Eric transports his Score in one, so we know it fits. Wrap the components in bubble wrap and slide them into one end, then fill with plastic peanuts, then slide the corresponding and slightly larger half onto the smaller half. One look at the device is worth this thousand or so words.
Hi Mike,
Thank you for the details. The Sport Tube looks like the perfect solution for transporting our "take apart" models:
http://www.sportube.com/pages/snowboards.html
At 7 7/8" x 14" x 72" it should haul most of our CL planes. At 14 lbs. + a 5 lbs plane, this makes for a very light transport package. At $169 it is a very good deal, and saves a lot of time and effort by having a RTT unit rather than a BOB unit. ;-) It can go on almost all airlines as one of our bags, but I like the idea that they recommend shipping by UPS/FedEx. This would save a lot of hassales at the AP. This has worked well for me in the past.
I enjoyed seeing your cool take apart plane at the CA state champs several weeks ago. Your KIS method of taking apart the wing, LG, and tail was perfect. y1
I will contact Jim, and Larry. They may know how to contact Eric. It would be interesting to see what he is using in his ECL Score.
Thanks again for all your help. I hope you get a chance to come down to our SoCal KOTRC contests in 2008.
Regards, H^^
This Modified Score has been a take apart for about a year. Stalker .66, Monokote on wings ,stab, .5 oz glass cloth on fuse applied with foam friendly zap glue! Base coat clear coat on fuse rudder. 67 oz. Great for testing engines .
(http://i82.photobucket.com/albums/j262/kickercoach12/KA10FOOTBALLINDIO041.jpg)
(http://i82.photobucket.com/albums/j262/kickercoach12/KA10FOOTBALLINDIO039.jpg)
Hi Walter,
That is a great looking plane, and by making it an ARC 1st you can get full _ _ _ rule points too! Others have said it is a great flying plane, and that it is competitive. Do you agree? TIA H^^
