Building Tips and technical articles. => ARF'S => Topic started by: Mike Greb on July 02, 2010, 11:09:44 AM
Has anybody assembled a Strega with the 2 part wing? I am assembling one on a very tight time budget. So far, I an replacing the control horns and pushrods, and relocating the bellcrank so that the pushrod is in line with the centerline of the wing due to the control horn I have available. I need to know if there is anything else new with the 2 part wing model.
Got it together, but the landing gear blocks are aready wobbly from just assembly. Anybody have a quick fix that can be done in a motel room? It looks like I am going to have to go into the bottom of the wing and epoxy a block of maple in somehow, but no time right now. Got to pack.
Big DUH factor going here. I was trying to use recylced landing gear from another plane. I did not realise that there was a block glued in to the top of the wing, and the gear was supposed to go to go all the way through the wing. The stock gear with a set of really big wheels has clearance for a 14" prop. now to fix the gaping hole in the bottom of the wing then I can finish packing.
