Building Tips and technical articles. => ARF'S => Topic started by: Frank Imbriaco on March 02, 2011, 03:30:40 PM
Gents,
Anyone know the stock incidence settings for the stab & wing?
I've been told that the Nobler ARF is similar to the 57 ??
Otherwise, I'm going with zero-zero .
That , along with 2-3 degrees right offset on the engine.
:! Frank, if memory serves I set my arf at 0-0 and put a .010 shim under the front of the motor to put just a small amount of down thrust in the engine.
As for side thrust just enough to know that it doesn't have any "in" thrust.
Oh, I also installed adj lead out's.
Hope that this helps... #^
Stay with zero settings on the ARF Nobler. I had to do some cutting to get the wing to match the stab and engine mounts. And a little offset of engine to outside of circle does not hurt as long as it is not excessive. H^^
I had to use thrust wedges to get downthrust in the engine from my first NoblARF.
My ARF profile Nobler.
