Building Tips and technical articles. => ARF'S => Topic started by: Dan Bregar on October 22, 2013, 10:53:12 AM
Does anyone know a good method to remove the (I think hot glue) that is used in the Brodak ARF's ? ???
Dan,
I don't know if it can be chemically removed, but I've had pretty good luck using a heat gun and a wood or plastic scraper. I use the gun tip attachment that reduces the air flow down to a fan shape. Takes a while, but works pretty well.
