Building Tips and technical articles. => ARF'S => Topic started by: Shawn Kuntz on June 12, 2007, 11:56:55 AM
Just got a Brodak Baby Clown ARF. Assembled it in about three hours. Put on my old Cox Black Widow after installing a factory rebuild kit. Haven't flown it yet but hope to soon. It is going to be a fun little airplane.
You should ahve a lot of fun with that set up! y1 The Black Widow will let you do a pretty good pattern with the baby Clown. Of course, you will have to refuel in the middle! LOL!!
Off topic, is the Johnson running? I was concerned with the compression being a *little* weak, but a lot of castor in the fuel should make it a runner.
That's OK, here on the Left Coast, we allow pit stops for engines under 1cc. I won 2nd in 1cc last year at the Goyet contest with a Black
Widow powered model that reqired 2 pit stops, and still made it under 8 minutes. (not by much, and I had Brett Buck for pit crew)
The model is the one you see under my nametag.
I just noticed the prop you have on the plane. If it is an OLD Top Flite, I have found that they are now too brittle to trust. They can throw a blade! After having one break in a hard landing, I tried flexing the remaining blade and it snapped in my hand. Seriously ungood.
It is highly recommended that you get a more modern prop. An APC 5.7x3 should be a good choice for the Black Widow.
Bill,
The Johnson is still on hold. I have to finish my kit bashed Twister first then do some work outside the house while summer is here. My next model project is going to be an RSM Ringmaster. I may put the Johnson in that it I can get it to run. If not then a Fox 35 will go in the Ringmaster. I will keep you posted once I get going on it.
Bill,
Great! And I really like the t-shirt! ;D
I flew the Baby Clown for the first time yesterday afternoon. It was hot and windy but the Baby Clown survived the first flights without a scratch. I got four flights in before calling it a day. The Blackwidow ran good on Sig 35%. I used 30' dacron lines. I think the Blackwidow would easily handle longer lines.
Hi Shawn,
Glad it is a good one! The Black Widow is surprisingly good, ain't it. y1
I am schocked to see that Bismark, ND is expecting higher temps for Saturday that we are here in "Hades", NC! That ain't right............ **)
Bill,
We have two seasons in North Dakota. Winter and Summer.
