Building Tips and technical articles. => ARF'S => Topic started by: John Rakes on November 01, 2007, 07:45:24 PM
Reading Jim Morris' post on the Vector Arf. One mentioned stiffening the motor mounts preventing vibration. I have not noticed this, or payed attention to my own if it needs stiffening. Could someone detail this a little for me please. Thanks
I think you are referring to gluing 3/8 to 1/2" thick balsa pieces (medium weight) between the two beams (the size depends on the thickness of the hardwood mounts). This effectively ties the right and left sides of the fuse into a solid block. This is done in the tank compartment. Another bonus is that balsa is a nice vibration absorber--much better than maple for example which is so hard that it can make a ringing sound. The grain direction is directed between the hardwood beams.
Ok Sounds easy enough, just remove some of the tank mount. Add balsa about the same size perpindicular to the beams. I will do this as far forward as I can, and I may do this also as far back to the wing as well. This sounds worth while. Thanks
I believe the arf I got already has them tied together,eccept for where the engine goes of course.BTW John,I wont be able to do anything this weekend,probably not for a while,at least until deer season is over. Priorities. Then come on down for the chili cook.
