Building Tips and technical articles. => ARF'S => Topic started by: Terry Bolin on August 11, 2007, 06:51:43 AM
Title: "Vector" Arf
Post by: Terry Bolin on August 11, 2007, 06:51:43 AM
I sold a Ringmaster RTF and used the money to buy a Vector from Sam's Hobbies. What changes did anyone make to the plane or what needs to be done if anything? Thanks, Terry Bolin. Neosho, MO
Title: Re: "Vector" Arf
Post by: john e. holliday on August 11, 2007, 09:25:22 AM
Is that the Vector 40 ARF?  I have the Vector 40 ARC that I am going to go with the control system from CLC.  The Brodak 40 is the power slated for it.  Have fun,  DOC Holliday
Post by: Terry Bolin on August 11, 2007, 07:59:34 PM
That's the right one. The 40 size ARF From Sam's.
T
Post by: Bob Hudak on August 14, 2007, 08:04:05 PM
After you get the covering shrunk back down go over all the seams with FletchTite thinned with MEK to brush consistency. I don't like the hinges supplied,they are stiff. My next one will have pinned nylon hinges. I made no changes to the building plans and it flies good.Weight came to 44 oz. with a OS 40 FP on a tongue muffler.
Post by: Patrick Rowan on August 15, 2007, 11:05:41 PM
I used Dubro hinges. I also used Clear Ultra Coat covering in many places to help keep the China film stuck down.
I flew my Vector ARFs first 4 flights on Wed 8-15-07. Full pattern on 2nd flight. By the 4th flight with triming done between each flight I was very happy. I have an ARF contest in 10 days & I would enter it if it was tomarrow. As you can tell I think it flys well.
I powered it with a LA 46, APC 11-4 prop.
I'm still hunting for the right spinner.
Post by: peabody on August 16, 2007, 05:22:58 AM
Post what you think is the right spinner, Pat....so far, none have appeared....
Jack Weston built and flew an electric Vector in Expert last Sunday and it was quite impressive....
Post by: Ward Van Duzer on August 18, 2007, 02:28:53 PM
OK...So what's the issue with the spinner?
W.  ???
Post by: peabody on August 18, 2007, 08:17:10 PM
Hi Ward....the Chinesemen that do the ARF/ARCs for Brodak seem to convert all American fractional measurements into metrical...and stuff gets lost in translation....I suspect that the spinner issue is that the plans call for a 2"(?) and the Chinesemen make them 50 mm?
Anyhow, the Brodak stuff to date does not take spinners that John sells....
Post by: Terry Bolin on August 19, 2007, 09:10:23 PM
Okay, did anyone see a need to alter the control system? I see the lines looped into the bellcrank with no bushing under the lines, problem there?
Terry B.
Post by: Bill Little on August 24, 2007, 06:57:33 AM
Terry B.
Terry,
Is it a nylon BC?  If so, you can get by for a long time, usually, with no bushing on the leadouts.  If it is metal, it needs to be tossed right now, or at least sleeve the leadouts with 1/16th brass tube in a horseshoe style.  I have seen plenty of cases where this type of "sleeve" has been used on nylon BCs also.
I do not have, nor have I seen, the controls in the ARF.
Post by: Dennis Saydak on August 24, 2007, 11:30:26 AM
Terry, a buddy and I built a pair of ARF Vectors. They fly great!
I bushed my control horns with 3/32" I.D. brass tubing and also slipped a length of carbon fiber tubing over the main pushrod (Tom Morris style) to prevent bowing. The pushrod with clevis that came in our kits was pure junk. The wire is far to soft to use as a pushrod. Under no circumstances use such a clevis. My clevis fell in half the first time I touched it. I replaced the rear pushrod with 3/32" piano wire. Hope this helps.
Post by: Alan Hayes on August 24, 2007, 09:16:39 PM
Hi Dennis,
Would you mind telling me what engines the two of you are using in your Vectors?  I wanted to use a reworked
40FP but there is a sizable gap between the nose ring and the face of the drive washer. Even with a recessed backplate I have about 3/16 gap. I just hate to have to add to the nose ring but I may have to.
Alan
Post by: Alan Hayes on August 26, 2007, 08:40:57 AM
This is a correction to my last post on August 24 referencing a 40FP and spinner backplate spacing. With 1/32" spacing between firewall and backplate bolts I have a spacing of 1/8" between the nose ring and face of the drive washer. Using a CG nylon recessed backplate spinner I now have less than 1/16" spacing.... less than 3/16" spacing as stated before.....big difference!
My problem was the Dubro spinner I was using not sitting against the drive washer due to the locknuts in the spinner backplate........"the main problem was trying to do this late at night".....it's amazing what a clear mind can achieve........lol.
Still do not have the proper Diameter fit............
Alan
Post by: Dennis Saydak on August 26, 2007, 09:12:03 AM
Alan, I have a Tom Dixon Magnum GP40 in mine and the other one has an OSFP40. I used 3/32" aluminum pads under the engine lugs which puts the engine slightly out of vertical alignment with the nose. I didn't worry about that or the large spinner gap since these two models are test beds in preparation for building two more Vectors from the built up kit.
Post by: Larry Wong on August 26, 2007, 05:02:41 PM
Picture of Dan Gomez New  Vector ARF with Magnum 36 XL and Bill Lee 11.4X4  3 blade Prop Uses 4.5 oz of fuel to do the pattern with laps of 5.2 at 10,850 RPM at launch.
Post by: Greg L Bahrman on August 26, 2007, 06:40:25 PM
Where can I get a Bill Lee prop like that for my 36 ??
Post by: Larry Wong on August 26, 2007, 07:15:18 PM
This is Bill Lee's site He has series G props that you need.
http://www.wrlee.com/EdomEnterprises/index.html
Post by: Greg L Bahrman on August 27, 2007, 09:34:09 PM
Thanks Larry,
Love your yellow Imitation
