  • June 16, 2025, 11:42:26 AM
Author Topic: ST.51 Cylinder Liner  (Read 4472 times)
« on: September 20, 2015, 08:35:45 PM »
  Hi Randy;
    Just picked up a ST.51 (recent version) that is the R/C version and was wondering if you have any C/L cylinder liners to convert it for stunt use? I have to dig out a parts sheet listing but I think I remember the only difference between the R/C and C/L versions is the venturi/needle valve and the cylinder liner. A good used one will do I guess also. Tower shows them as "order pending" but we know what that can mean! This engine I have is new and never been run.
  Thanks a lot,
Re: ST.51 Cylinder Liner
« Reply #1 on: September 21, 2015, 09:19:56 AM »
  Hi Randy;
  Thanks a lot,
Hi Dan  I will need to check, I have the ST parts boxed in storage, I will PM or email later
Also if one can't be found, I can make the stock one work.
regards
« Reply #2 on: September 21, 2015, 09:43:42 PM »
  Okie dokie. No hurry, just would like to get it changed before I forget what it is! y1
  Thanks a lot,
