Vendors Corner => Aero Products => Topic started by: Mike Foley on April 17, 2007, 12:59:54 PM
Recently purchased your tongue muffler from Brodaqk for the Brodak 40. Muffler fits the motor perfectly however the mounting bolts do not line up. Off by approximately 1/16 to 1/8. Obviously the muffler mounting holes need enlarging. What is the proper way to do this?
Thanks!
Thanks!
Hi Mike
The way to enlarge holes is with a larger drill bit, or a reamer
I just went and measured a Brodak 40 it is 1.115 inches, my muffler bolt spacing is 1.115 inches, all of them I looked at were the same, However the muffler was made to fit the HP 40 FSR 40-45 and some of the FOX 40s so opening up the holes slightly is no problem. If you do have a muffler that is off by 1/8 inch I would like to see it. If you feel that it is a big problem you can ship it back to Brodak or to me
REgards
Thanks for the reply Randy. The bolt spacing is maybe off by 1/32" after looking closer with my glasses on. No biggy, I will drill it out slightly and it will be fine. I will say very nice quality and feather light.
Thanks!
