Vendors Corner => Aero Products => Topic started by: Dennis Leonhardi on April 09, 2010, 03:59:24 PM
Randy, I have NIB Thunder Tiger with helicopter head & throttle assembly. Can you provide a head, venturi & needle assembly for this? If so, wht is the cost and what can I expect in terms of running characteristics for sport flying?
Also, is the Magnum .36 virtually the same when stripped of throttle assembly? I assume the heads are iudentical?
Thanks for your great service!
Dennis
Hi Do you just want it to be a CL engine? or do you want it converted to a Aero Tiger?
I can do either
Just control line sport basically. Is the Magnum engine identical for all practical urposes? Thanks!
Dennis
Dennis
NO the Magnum is not even close to identical to the TT
