  • July 17, 2025, 06:15:09 PM
Author Topic: SV-11 Specifics  (Read 3783 times)
Offline Frank Imbriaco
SV-11 Specifics
« on: July 01, 2011, 02:45:56 PM »
Hi Randy,
I'm finishing up an SV-11 ARC that is e-powered. Do you recommend any right offset for the vertical fin/rudder and what is a good starting point for the leadouts.
Thanks!
Online RandySmith
Re: SV-11 Specifics
« Reply #1 on: July 03, 2011, 08:16:37 PM »
Hi Randy,
Thanks!
I do not use any, however it would be a good idea to make it adjustable so you can put some in if needed
The leadouts ,will be close to the highpoint of the tip airfoil, if the CG is as on the plan
If not hang the plane by the leadouts, slide the back n forth untill the planes fuse is perfect level and then move back 3/16 inch. That will be close to start
Re: SV-11 Specifics
« Reply #2 on: July 04, 2011, 08:47:58 PM »
Thanks !
