  • July 12, 2025, 11:16:51 AM
Author Topic: Parts, Piston/Sleeve, cases , Cranks, OS ST COX Magnum Thunder Tiger  (Read 12094 times)
2- OS 40 VF mid main case $44.70
1- OS  45  FSR  mid main case   $39.95
1-OS 45 FSR  lapped piston sleeve set  ABC stock OS part $92.50
1-OS 40 FSR lapped piston sleeve set ABC stock OS part  $89.50
1-45 OS FSR crankshaft 24902109 NIP FSR-S  stunt crank   $44.00
1-45 FSR  crankshaft 24902202          $44.00
1- 45 FSR  piston for ring version  $ 29.95
1- 45 FSR piston sleeve set  for  ringed version24808224    $75.00
1- OS 46  VF  abc  piston/sleeve set  $89.95
1- OS 45 FSR  - RSR  Cylinder sleeve for ring piston 24803120   $39.95
1- 25 VF  OS  crankshaft   $35.00
1- 40 VF  OS  crankshaft      $49.95
1- 46 Vf  OS  crankshaft   $ 49.95
1- OS 40 VF AAC Special  piston/sleeve  set  $109.00
1- OS 40  FSR  cylinder sleeve   22903100  $39.95
1- OS 32 H and  OS 32 F  sleeve for ring version  $38.00
1- OS  32  F  ABC lapped piston / Sleeve set     $65.00
1- OS 35 S  piston sleeve set   $65.00
1- OS 30 -S  piston Sleeve set  $50.00
1- OS 35-S  crankshaft   $40.00
1- OS   30-S  Case  will fit either 35 or 30  $45.00
1- OS 25 Blue pack crankcase for 1970s model baffle motor $ 29.00
1- OS 25 Blue pack crankshaft for 1970s model baffle motor $ 29.00
1- OS 25 Blue pack HEAD for 1970s model baffle motor $ 15.00
1- OS 25 Blue pack Piston Sleeve  set for 1970s model baffle motor $ 39.00
4- Piston Sleeve sets  for  LA 46 ABC OS stock   $ 49.00
3- Crankshafts   OS LA 46 $29.95  These also are to fit 35 FP. 40 FP. 40 LA
Most all parts for  LA 46
2- piston / sleeve sets for  OS Max 06   $29.95
3- Piston / sleeve sets for  OS MAX 10S baffled, also 10 R/C  $29.95
1- OS 60 GFR alum baffled piston $26.00
1- OS 20FP piston sleeve set  22303010   $32.00
2- LA 15  piston sleeve sets  $29.00
..........OPS...........
1- AAC special piston sleeve set  OPS  40  SPA  CL stunt  $110  These are the same one that  built so many engines  with
1-ABC  OPS Stock  low time  piston sleeve set       $89.95
Randy Smith    Randyaero@msn.com     ALL PARTS  ARE  NEW ,STOCK ,OS PARTS ,UNLESS MARKED   SPECIAL ! Like the  AAC sets
« Last Edit: April 25, 2018, 12:59:50 PM by RandySmith »
If these are ABC I'll take one but, did you mean ABN?
Motorman
OS made  piston sleeves  they call it    ABC    but  it is  really nickle plated,  that is  also the  reason I wrote STOCK  on them
Offline MikeyPratt
Hi Randy,
Have you had a chance to inspect HP Gold Cup 40 yet?  I sent it with Aero Tiger and the black Fox.  This the HP 40 you built for me with a true ABC (no ring).  It ran Super for many years and then it started spraying black junk all over the wing and running like crap.
Later,
Mikey
Hi Randy,
Later,
Mikey
Hi Mikey    Not yet  but I will  get  to it soon and  let you know
