  • July 30, 2025, 05:50:47 AM
Author Topic: PA needle valves assemblies back in stock  (Read 12896 times)
« on: January 15, 2017, 07:38:12 PM »
PA  needle valves assemblies  back in stock, along  with all parts
Randy            678 407 9376     Randyaero@msn.com
Offline Steve Dwyer
Re: PA needle valves assemblies back in stock
« Reply #1 on: July 01, 2018, 09:04:42 AM »
Randy,
 I'm trying to convert an OS FP 40 over to control line, tower doesn't show the NVA assemblies available, someone said I should check with you that your PA assembly should work. Do you recommend your assembly for the FP40 and what is the charge? Do you have any info on the PA, photos etc.?
« Reply #2 on: July 02, 2018, 08:52:13 AM »
Randy,
Hi Steve  the  PA  is the  best  NVA, but you will have to drill the case across for the  NVA, it is same diameter  as the  ST  Enya  and  old  OS
you would use a  281 venturi with my PA or  ST  Enya, the  Stock  NVA  uses a  .255  venturi   The  pa  is  19.99   venturis  are  12.00   . I have  a few  OS  NVAs left, they are 19.99  each
So I can supply you with  whatever  you  want ,  and  I also have  100s  of parts in stock for  other  OS  LA  engines  and many FPs
Randy  678 407 9376
