  • July 03, 2025, 09:48:16 AM
Author Topic: Pipe length for PA 61  (Read 5985 times)
Offline James Mills
« on: April 21, 2010, 09:40:34 PM »
I've almost finished my Tempest.  Going to be about 65 ounces with PA 61 on pipe, what pipe length should I start with?
James
AMA 491167
Re: Pipe length for PA 61
« Reply #1 on: April 21, 2010, 10:34:00 PM »
James
Depends on the RPM  prop combo, what are you using?
Offline James Mills
« Reply #2 on: April 23, 2010, 10:51:46 PM »
Randy,
I plan to use bolly 3 blades 12-12.5 range.
James
AMA 491167
« Reply #3 on: April 24, 2010, 09:38:13 AM »
Randy,
James
Hi
You can use a pipe lenght of 17 3/4 to 18 inches from first baffle to glo plug, launch with the motor running in the fastes 4 cycle it will run in ,or just starting to crack back n forth in a 4-2. The motor will drop into a solid 4 cycle within 1/2 a lap after launch, then it will beep 2 cycle across the tops of the manouvers.
If the setup is flying too slow pitch the prop up..do not use the needle as a speed control.
If the setup is going too fast [pitch the prop down..do not turn the needle richer.
If the setup slows or sags in the tops of manouvers add nitro... If the setup runs too fast or charges thru manouvers  cut the nitro percentages. I use this setup with 5% nitro in cool months and then going to 10% in hotter months
Offline James Mills
« Reply #4 on: April 24, 2010, 09:58:42 AM »
Hi
Thanks Randy.  I have the header at full length.  If I need to trim to get the length of the pipe down should I cut the pipe?
James
AMA 491167
Offline Allan Perret
  • Proverbs
« Reply #5 on: April 26, 2010, 07:57:07 AM »
Hey Randy:
Just want to make sure I am clear on proper way to measure the pipe length.
When you say "to the glow plug" you mean starting at the plug tip, measuring thru the combustion chamber and out of the exhaust port, right ??
On my PA65RE, measuring from plug tip to exhaust port flange I get  about  1 5/8", does that sound about right ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #6 on: April 27, 2010, 11:18:03 AM »
Hey Randy:
Allan
All of my newer design pipes have a 1/10th inch bump at the back of the pipe, this is where the first reflective surface is (baffle), Measure in a straight line from there to the peg on the glo plug
