  • August 01, 2025, 03:08:46 AM
Author Topic: NEW ENYA Pro 32 side and Rear Motors  (Read 7220 times)
« on: May 19, 2009, 11:13:36 PM »
The NEW ENYA  32 Pro BB  Stunt motors are now in stock. I have both side and Rear EX in stock. Plus I have the Rear header in stock for them also
I will post pictures , and more info tommorow
These are very nice dual balll bearing 32, 1 is  a  side Exhaust with muffler, sells for around 130.00 the other is a rear exhaust 32 ,engine alone, that sells for 144.00. I have light CNC tube mufflers, and  rear headers  for the  Enya 32 RE
They are  The 32 CXLS rear  and  32CXS  side
« Last Edit: May 20, 2009, 08:30:10 PM by RandySmith »
Offline Allan Perret
  • Proverbs
Re: NEW ENYA Pro 32 side and Rear Motors
« Reply #1 on: May 22, 2009, 09:28:09 AM »
I know its too early with this new engine to have any real world experience with it, but what is you best guess as to the upper range of plane size that it will be a good match for.  I talking about the RE on a pipe.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #2 on: May 22, 2009, 03:17:41 PM »
Hi Allan
I would think easily,t would pull a 55 ouncer, although A VECTOR 40 Size plane would be ideal at about 44 ounces
Offline Balsa Butcher
  • High Desert Flier
« Reply #3 on: May 22, 2009, 10:46:30 PM »
By any chance would the Enya Pro 32 use the same mounting bolt pattern as the Evo/Magnum/TT/AeroTiger 36 engines?
Thanks Randy 8)
« Last Edit: May 23, 2009, 07:38:18 PM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #4 on: May 23, 2009, 03:12:04 PM »
Hi Pete
No it is not exact, but it is very close, it will be no problem retrofitting one in. and the case width is just a tiny bit smaller on the Enya
Offline Michael Reed
« Reply #5 on: February 26, 2011, 10:14:34 PM »
How close would the .32 side exhaust fit a fox .35 mounting. I picked up a decent Nobler that had the Fox .35 and was looking at this engine for it.
« Reply #6 on: March 01, 2011, 08:26:46 AM »
Hi Michael
The motor is not a drop in fit for a FOX 35, it is much longer
