  • July 18, 2025, 01:34:22 AM
Author Topic: New cnc mufflers  (Read 16707 times)
New cnc mufflers
« on: November 19, 2007, 10:57:08 AM »
HI Everyone
I have new cnc tongue mufflers for the ENYA 60 and others with 42mm  bolt span
Also all CNC tongue mufflers are back in stock, Plus new ones for the ST G-34
www.aeroproduct.net
Offline Allan Perret
  • Proverbs
Re: New cnc mufflers
« Reply #1 on: January 09, 2008, 08:50:23 AM »
Do you have tongue muffler for Enya XZS 40?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #2 on: January 09, 2008, 07:23:35 PM »
Allan  I do not have the 40 XZS in stock yet, what are the  hole spacings on the case for the muffler?
Should be just shy of 1.40 inches
The web site shows that it takes the same muffler as a 35SS  if that is so I have a muffler for it both cnc tongue or  cnc Tube. It will use the  Thunder Tiger, Aero Tiger, Magnum 36 mufflers
« Reply #3 on: January 10, 2008, 02:53:11 PM »
The new  CNC  tube muffler  for tHe ENYA 61 CXS Pro  are now in stock, this motor has a  42mm span on teh bolts
  • Proverbs
« Reply #4 on: January 12, 2008, 09:48:21 AM »
Yes, I'm showing about 1.38" on the spacing of mounting bolts.
So what are the prices and weights of the tongue and tube you have?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #5 on: January 12, 2008, 02:39:56 PM »
HI Allan
My tongue mufflers  are high quality  CNC products and weigh about the same  as all the others out there. depends on which one you are asking about, the Brodak 40 tongue is the lightest, the ENYA 60 is the heaviest .5 ounce is average
My CNC product TUBE mufflers  are  very light and weigh just a little over 1 ounce, they  have  no front or rear caps to blowout or come loose
the  Aero Tongue mufflers  are 18.95
the CNC Aero Tubes are 39.95
« Reply #6 on: March 05, 2008, 03:53:38 PM »
Randy - I would like 2 of the tube mufflers for the 61CXS pro
should I just order through your website?
wingpro
« Reply #7 on: April 23, 2008, 09:22:19 PM »
HI Everyone
www.aeroproduct.net
Dear Randy,
My engine is ENYA 45SM, I need a tube muffler which screw spacing is also 42mm.
Does your muffler come with a "fixing belt"(strap) for ENYA old style engine such as 45SM?
Thanks.
wingpro
« Reply #8 on: April 24, 2008, 01:45:14 PM »
Dear Randy,
Thanks.
wingpro
HI
I have both cnc tube and tongue mufflers in stock for the 42MM  spacing of the ENYA bolt on. I do not have straps, but it is a very simple matter to pick one up at the local auto parts store, a stainless steel worm drive radiator strap will work with either of my mufflers, just let me know you are using a strap and I will send along 2 of the  4-40 x 1\4 inch bolt.
You simply open , or cut the strap in the middle,  and bolt each loose end to the back side of the tapped muffler.
wingpro
« Reply #9 on: April 24, 2008, 11:58:37 PM »
HI
Dear Randy,
Thanks for your detail information.
I will place my order by mail to you later.
wingpro
